Bed Bolts
Old Aug 21, 2015 | 04:50 PM
Gary Lewis's Avatar
Gary Lewis
Bed Bolts
I went up to see the progress on Dad's truck today and learned I needed to deliver the bed bolts. So, I went home and discovered I had a mix of them and wasn't sure what was needed. A lot of searching in the catalog found this:
Hmmm. That's pretty small, so here's a close-up of the 80-84 section:
Ok, now I have a set of numbers, what size are they? Turns out I couldn't find those numbers in the master parts catalog (maybe ND can), so I turned to Ford's Standard and Utility Parts Catalog. Bingo! However, as you can see below, they show them as metric bolts and mine are 1/2-13's. So, I entered the inch equivalent of those metric numbers and, sure enough, that's exactly what I have. I've recorded the inch #'s, in blue, for posterity.
And, here's what they look like - before powder coating. And, you might notice that one of them is a bit wasp-waisted. I've repaired it and will show that, as well as the powder-coated bolts in Dad's Truck Build.
Old Aug 21, 2015 | 08:47 PM
Gary Lewis's Avatar
Gary Lewis
I've done some looking and there are some sources for the bolts. However, you are likely to find some of them with a S437 finish instead of the S40 finish shown in the catalog. Here's the difference, from the Standard and Utility Parts Catalog:
  • S40: Zinc plate
  • S437: ELECTROLYTIC ZINC PLATE, TRIVALENT CHROMATE, LEACHED AND SEALED, INTEGRAL TORQUE CONTROL LUBRICANT: This finish is an electrolytic plating of zinc, followed by a trivalent chromate conversion, leached to a silver-white color in a sealer.
As for finding them, Amazon has one
N803020-S40 N803020-S40
bolt for $25.63. http://www.tascaparts.com/oe-ford/n803020s437 has it for $3.94, although it is an S437. And http://oemfordparts.jackyjones.com/oe-ford/n803020s437 has them for $4.80.
I don't find anyone selling the N803021.
Amazon Amazon
has the N803022 for $26.01. http://www.tascaparts.com/oe-ford/n803022s40 has them for $15.40, but it is an S40 so won't match the S437 exactly. And http://www.fordparts2u.com/oe-ford/n803022s40 has them for $19.67.
As for the N803023, Tasca has it for $20.07, and Ford Parts 2U has it for $26.18.
So, for about $80 plus shipping you could have 6 of the 8 bolts new. However, with no hits for the elusive N803021 then you are kinda stuck.
Old Aug 21, 2015 | 09:08 PM
Franklin2's Avatar
Franklin2
I guess you remember the previous threads and the several different ways around this? No way am I going to pay $80 for the bed bolts.
Double check your tubing on the bed where the bolts go through. If the tubing is a little bit bent or collapsed, the factory bolt will tighten down without clamping the bed tight to the frame.
Old Aug 21, 2015 | 09:11 PM
Gary Lewis's Avatar
Gary Lewis
Yes, I remember the threads and the ways around. I'm just documenting what I found so others don't have to jump through the same hoops I did today.
Old Aug 21, 2015 | 09:44 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
My bed bolts are 7/16-14 just like all Ford bell housings.
But my '87 truck only uses 6 bolts in the bed, four oval and two square under the head.
Old Aug 21, 2015 | 09:55 PM
Gary Lewis's Avatar
Gary Lewis
Interesting. The first drawing does show that in '85 Ford went to 6 bolts - the N803020, 22, and 23. In other words, they did away with the 21, which might explain why no one has them.
However, they show those bolts as being the same ones as for the 80 - 84 beds, and all the bolts I have are 1/2-13. And yet the # cross references to the metric bolts shown above. The plot thickens!
EDIT: Actually, what I have in "N803020" is a reference, not the part #. If I could find the proper place in the master parts catalog I'll bet it shows the 80 - 84's use 1/2-13's and the 85's and later use 7/16-14. And then at some point they became metric.
Old Aug 21, 2015 | 10:09 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I'm pretty sure the bolts have been superceded to metric in the supply chain.
My truck being '87 was a transition year for the new body style (new assembly line)
I don't know why they are the pitch they are, but I have checked them against both tap and die when I pulled the bed last week to change both senders.
One was rotten like yours.
I used a 1/2 -13 x 3 stainless carriage bolt and flange nut, then filed the bed floor until it fit.
Still WAY less expensive than OEM.
Old Aug 21, 2015 | 10:12 PM
Gary Lewis's Avatar
Gary Lewis
How did size of the head of the carriage bolt compare to the original bolt?
And, the "square" on the carriage bolt was bigger than the bed's opening?
Old Aug 22, 2015 | 12:06 AM
FordFETruck's Avatar
FordFETruck
Holy crap, Jim's alive. Haven't seen you on here in quite a long time.
The front right bed bolt on mine isn't fully tightened down. And that bed has never been off by the looks of the bolts and nuts. However the bolt just spins in the bed hole, looks like it would be the bolt with the round shoulder? Also seems the factory cross threaded that nut on. It was a Friday truck after all.
Old Aug 22, 2015 | 11:04 AM
tree medics's Avatar
tree medics
Gary, here is my invoice with the part #'s from 2006. I hope this helps. Pat
Old Aug 22, 2015 | 02:15 PM
Gary Lewis's Avatar
Gary Lewis
Pat - Thanks! That may well help those wanting to do this in future. But, a couple of questions:
  1. Metric: Did you check to see what size the bolts were? 1/2-13? 7/16-14? M12?
  2. Coating: I notice that the nuts were S437 and the others were S40. Could you tell the difference? I ask because I wonder if it would work to mix and match finishes on the bolts. Or, if there was enough difference to suggest they should all be the same.
Old Aug 22, 2015 | 03:52 PM
tree medics
1. No, I did not but I have pieces of the old ones. I can measure them, along with the new ones as soon as it stops raining ( truck is in a puddle.)
2. This is going from memory in 2007. I think the nuts were shiny like chrome compared to the bolts. I can take pictures of them once the rain stops. The nuts will be weathered. But just in case their still shiny.
Old Jul 19, 2017 | 06:23 PM
Bob10's Avatar
Bob10
I know this is long dead but damn those bolts are expensive and I need 3 The 2 long ones next to the cab and the one that has a clip on the drivers side just behind the wheel well. Funny thing is I put an 86 bed on an 80 truck and the ones that are supposed to be hard to find are extra as they don't have a home on my truck unless modify the bed
Old Jul 19, 2017 | 09:46 PM
reamer's Avatar
reamer
Flareside bolts have a tapered "Phillips Head" on them, and are actually called screws and need special-tapered washers...
Old Jul 19, 2017 | 11:46 PM
hardward's Avatar
hardward
these bolts called "schlossschraube" (yes, with 3 S's) or even DIN603 here in germany.
https://www.fk-soehnchen.de/werkstat...SABEgJbAfD_BwE
big link
maybe it helps a little.
hardy
