Transmission Issue
Old Sep 4, 2015 | 05:16 PM
AbitaPro's Avatar
AbitaPro
Ford may put out or already have software update to correct that issue, I would just check with your dealer when you stop in.
If you can think back to when your truck was brand new, did it do the same then? If not, perhaps disconnecting the battery for 15 minutes, then reconnect. I think that puts the transmission back into the learning mode, may help, shouldn't hurt.
Old Sep 8, 2015 | 04:45 PM
elemint's Avatar
elemint
Seriously? Why can't Ford make a problem free transmission??? It has been almost 30 years since I have heard of a problem free ford trans.! Why don't they just buy a known reliable trans from a competitor an copy the darn things?
Originally Posted by Airborne-F150
Took my 2015 in for the same clunk and the had to replace a few inner seals on the transmission. Had it back now a week and no clunking
Old Sep 9, 2015 | 05:00 AM
tseekins's Avatar
tseekins
Veteran: Coast Guard
This is a couple threads now that you've recently chimed in bangin' on Fords transmissions. I'm not sure where your coming from on your assessment of Fords transmission quality.
I've owned Fords exclusively since I was 17 years and had one failure that was my fault. I neglected to service the transmission on my 1985 Tempo and after 90K+ miles, it failed.
Old Sep 11, 2015 | 01:48 PM
Rickyrobert's Avatar
Rickyrobert
weird. i had the same thing happen with my 2011 ecoboost except when upshifting
Old Sep 15, 2015 | 06:36 PM
F150MUTT's Avatar
F150MUTT
2500 Km on my 5.0 xlt
I had three hard downshifts from 5th to 4th while passing with my trailer attached.
No more hard shifts for the past 2 weeks so I assume that the tranny was in learning mode.
The tranny upshifts and downshifts smoothly now in reg, tow or sport mode.
Old Sep 16, 2015 | 07:35 PM
Rancheroracer's Avatar
Rancheroracer
Poll for Hard Downshifts From 5th to 4th - Ford F150 Forum - Community of Ford Truck Fans
Old May 16, 2016 | 06:00 PM
chiggins's Avatar
chiggins
Not sure if this threads is still alive. I have a 2015 2.7 liter XLT and from a cold start going down my (kind of steep) long driveway the transmission make a clunking sound and shift from 1st to 3rd to 5th and then back to 3rd. When I stop it stays in 3rd and won't go back to 1st unless I turn the truck off then back on...took it to the shop and they said they couldn't duplicate the problem. Only happens maybe once every week of so. Anyone having anything like this going on?
Old May 17, 2016 | 12:33 AM
McObra's Avatar
McObra
Mine has a very firm downshift from 5th to 4th, but only in the sport mode. Never noticed it in the economy mode. I'll ask the dealer about it next time it's in for service.
Old May 17, 2016 | 08:52 AM
GlueGuy's Avatar
GlueGuy
No wandering shifting here, but I do notice a considerable lag when commanding a shift from 2nd to 1st. We also have a rather long driveway with a couple of steep declines. I typically drop the tranny into 1st on purpose to go down a couple of the declines, and it takes 5 to 10 seconds before the transmission actually goes into 1st. Often it's a rather rough shift too. This is while going between 5 and 10 MPH.
Old May 17, 2016 | 11:05 AM
rmccbride's Avatar
rmccbride
My transmission as been perfect since I had the TSB done to it..
Old May 17, 2016 | 12:07 PM
GlueGuy's Avatar
GlueGuy
TSB on the tranny?!? Got a link or something?
Old May 17, 2016 | 01:26 PM
rmccbride's Avatar
rmccbride
http://www.f150forum.com/attachments...tsb16-0015.pdf
Old May 17, 2016 | 02:55 PM
  #28
jr105's Avatar
jr105
I had this TSB done and the transmission downshift issue is fixed, however I wound up with a CEL (P0315) after the reprogramming of the PCM. If this happens Ford has a fix for it. Special service message #698298 has the tech do a "misfire monitor neutral profile correction" with a scan tool.
Old Jan 2, 2017 | 09:31 AM
  #29
Trail_Rider's Avatar
Trail_Rider
My son was having this problem with his 15 - 5.0 and simply had the trans reflashed. That seemed to take care of it.
Old Jan 2, 2017 | 04:02 PM
  #30
UPS92008's Avatar
UPS92008
My 2015 EB FX4 has done a few slamming shifts in the 6 months that I've owned to truck. Going from 5th to 4th under very low gas pedal input and from 3rd to 4th with the same amount of pedal. The 3.5 makes lots of torque down low on the tach. I cant repeat it. I wonder the if the torque is starting to come on and the tranny shifts normally? It is odd. I feel it for sure. It's alarming when it does it.
F TOO FITTY
Sep 11, 2018 08:32 AM
kupiec20
24
Jul 10, 2010 10:05 PM
millermanbg
Jun 29, 2009 09:45 PM
KING
Dec 6, 2007 09:13 AM
ColonyPark
Nov 3, 2005 01:05 AM
