starter/ flywheel probs
Old Aug 19, 2015 | 02:24 PM
haaaammmmmm's Avatar
haaaammmmmm
Hey guys, I'm dealing with a 1988 f150, the trans is a original m5r2, and the flywheel match that, but the engine is a 302 out of a 78, I cant seem to get the starter to grab, any wich way I shim or adjust it, just makes the Chevy grinding noise but wont turn the engine, I was told to put a auto starter on it to fix this issue, any input?! Thanks alot
Old Aug 19, 2015 | 03:21 PM
jas88's Avatar
jas88
Is the starter from the 78 motor? Or from the 88 motor? What about the flywheel?
Old Aug 19, 2015 | 04:44 PM
Willz74's Avatar
Willz74
Get a starter for the 88 year if you use the wrong starter they grind the gear should be inside the starter nose if not it just stays engaged while the motor runs
1984F-150
Sep 13, 2023 03:18 PM
beckman
1947 and Older Ford Trucks
Apr 29, 2013 12:08 AM
cowboy417
Bronco II
13
Aug 20, 2012 10:57 AM
BroncJMU
1978 - 1996 Big Bronco
Dec 21, 2004 08:20 PM
blueovalinvestments
Sep 18, 2003 11:59 AM
