starter issue
Old Apr 28, 2013 | 07:18 PM
beckman's Avatar
beckman
starter issue
hi guys i have a 1947 ford 1 ton flathead v8 and the motor turns over by hand but when battery is hooked up the starter motor just spins and doesnt turn the engine over would a starter from a 1951 ford truck work on a 1947
Old Apr 28, 2013 | 08:12 PM
f5fordgirl's Avatar
f5fordgirl
Should be the same thing.
Old Apr 29, 2013 | 12:08 AM
46fordtruck's Avatar
46fordtruck
They are the same. Sounds like one of two things, either a bad Bendix drive that doesn't push out to engage the flywheel or missing teeth on the flywheel. When you remove starter check the teeth on the flywheel.
zech
1983 - 2012 Ranger & B-Series
Oct 17, 2022 02:26 PM
cartune
1997 - 2003 F150
Jan 1, 2007 08:20 PM
desperado_18_2000
Feb 16, 2004 07:06 PM
bronco Jr.
3.8 & 4.2L V6
Jul 25, 2003 09:48 AM
RedBilly
17
Feb 5, 2003 09:00 PM
