Engine noise/vibration in cab
Old Aug 18, 2015 | 11:18 PM
Macrobb's Avatar
Macrobb
OK, guys.
My 88 has always been a bit loud. It also vibrates with the engine -- I put my foot on the floor and I can feel any engine vibration. Same with the steering wheel.
As far as I know, the motor mounts are solid for the 7.3; Is there any way of quieting/"decoupling" the cab from the motor noises?
Thanks,
-Rob
Old Aug 19, 2015 | 05:38 AM
hturner12's Avatar
hturner12
Rob
You could use dynamax or this
EZ Cool Car Insulation Kit | Low-E SSR Products
Check your cab mount bushings
Old Aug 19, 2015 | 09:59 AM
tecgod13's Avatar
tecgod13
The motor mounts are NOT solid! Check your motor mounts, they are stiff, but there is some rubber in there. I replaced mine at one point, but can't recall if it made a difference or not.
x2 on checking the cab mount bushings. If they are shot, the cab will be resting on the frame and transmitting vibrations directly. Also check to make sure the exhaust piping isn't touching the cab anywhere.
Old Aug 19, 2015 | 11:05 AM
hturner12's Avatar
hturner12
Originally Posted by Macrobb
OK, guys.
Thanks,
-Rob
My vibration was the swing bearing on the driveshaft.
Old Aug 19, 2015 | 03:00 PM
dropitlow88's Avatar
dropitlow88
i have noticed the same thing on mine. I just chocked it up to being an old diesel pickup. She has yet to let me down. Although recently i have been getting a strange vibration upon decel. i believe the carrier bearing is getting tired.
Old Aug 20, 2015 | 10:25 PM
Macrobb's Avatar
Macrobb
Well... I figured I might as well put in some cab mounts.
Couldn't get the middle set loose, but they were still rubber-y. Added 3/4" of shims to the top.
I then found that my right /front/ mount was entirely disconnected. Bolt totally sheared. The left front mount was intact, but worn.
I'll be replacing them as soon as I can, and adding shims... Might as well give myself a little extra clearance.
8 Lugs
Feb 27, 2017 01:41 PM
Number21
Feb 19, 2014 08:46 PM
koboss1
6.4L Power Stroke Diesel
30
Aug 17, 2010 06:44 AM
Ranger92
General Automotive Discussion
Nov 22, 2008 02:24 AM
77f150got_sand
Jan 5, 2008 11:08 PM
