Front U joint question
Old Aug 17, 2015 | 12:29 PM
jasefm's Avatar
jasefm
So the front u joint in my 2001 Expy is loose and making a clicking sound. Its the u joint on the rear of the front drive shaft. Do I just remove the front four bolts to drop it? Can I drive the truck without the front drive shaft in?
Thanks in advance.
Old Aug 19, 2015 | 09:56 PM
The2003Excursion's Avatar
The2003Excursion
You can run without a front drive shift in 2wd mode no problem. I have heard someone talk about running in fwd with 4wd engaged with the rear shaft gone too. In the snow , not dry pavement.
Old Aug 20, 2015 | 03:04 PM
jasefm's Avatar
jasefm
awd
I only have AWD, 4H, and 4low. Can I remove fuse 104? to make it 2wd?
Old Aug 21, 2015 | 02:54 AM
The2003Excursion
Do a search for the brown wire mod
Old Aug 22, 2015 | 10:03 AM
alloro's Avatar
alloro
Yes but the driveshaft will always turn for your model year since there is no way to disengage it from the front axle.
geoff69a1
Apr 15, 2018 01:18 PM
justin_brandstein
29
Dec 21, 2013 01:53 PM
chefddh
1966 - 1977 Early Broncos
Sep 24, 2006 05:56 PM
97BlueF150
1997 - 2003 F150
Apr 22, 2004 03:57 PM
ronmoon
Feb 13, 2004 09:51 AM
