front drive shaft
Old Feb 12, 2004 | 08:29 AM
ronmoon's Avatar
ronmoon
front drive shaft
Hello, I have a 2000 4WD XLT Expedition and have some vibration in the front end. After crawling around under it I found that the rear U joint is bad and needs replaced. My question is should i replace the U joints or go ahead and replace the entire shaft? Also with it not being a solid shaft and having the boot in the middle of it, is there more servicable parts to this driveshaft than just the U joints?
Old Feb 12, 2004 | 11:51 AM
dakota_viking's Avatar
dakota_viking
I think it would be more cost effective to just replace the U-joint. A whole shaft would run quite a bit more.
As for the the rest of the shaft, as long as the boot looks good and there are not cracks in it, everything should be good to go!
Good luck,
Tim
Old Feb 12, 2004 | 12:12 PM
buzzard's Avatar
buzzard
I agree, u-joints are cheap and can wear out. Shafts are expensive and generally don't require any maintenance. Just make sure you "index" everything before removal of any components.
Old Feb 13, 2004 | 09:51 AM
ronmoon's Avatar
ronmoon
Thanks for the info, I bought the U joints and will replace them today. I'll let you know if I have any more problems... Thanks again.
