Fuse Block Mounting
Old Aug 16, 2015 | 03:34 PM
Cougar54's Avatar
Cougar54
Fuse Block Mounting
I will start wiring my '50 F2 for 12V soon and have a universal wiring harness to completely replace the original wiring. My question is has anyone found the "best" place to install the fuse block inside the cab? I thought I saw a picture of one mounted in the drivers side kick panel area but I forgot to bookmark it and I'll be darned if I can find it now. Any suggestions?
Old Aug 16, 2015 | 04:40 PM
Harrier's Avatar
Harrier
Will this thread help you?
https://www.ford-trucks.com/forums/1...l#post15161300
I'm doing something similar to what is in post #8. But my box is a little too big so I'm putting mine on the firewall.
Old Aug 16, 2015 | 05:10 PM
Cougar54's Avatar
Cougar54
Well that's an interesting way to mount it. I like the use of a magnet to hold it in place. Any other ideas?
Old Aug 16, 2015 | 06:32 PM
Rimrock F1's Avatar
Rimrock F1
I installed mine behind the drivers side kick panel on a 52, should work on a 54 also.
Old Aug 16, 2015 | 06:56 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
I was going to post a pic of mine, but I remember I have in the past so I went and dug up one of the old threads instead.
Here is another old thread about fuse box locations;
https://www.ford-trucks.com/forums/9...placement.html
Bobby
Old Aug 16, 2015 | 08:44 PM
toby tough's Avatar
toby tough
I always thought I would put mine in the glovebox, The cardboard bits are toast and was going to make a new one out of some light gauge metal. Thought I would insulate. the block from the metal with some EPDM or similar stuff. I'm quite a ways out till I'm ready for wiring though. It's just a idea right now.
Old Aug 16, 2015 | 10:32 PM
Cougar54's Avatar
Cougar54
Well now I have some a few ideas where to put the block. Thanks for the insight.
Old Aug 18, 2015 | 02:10 PM
CharlieLed's Avatar
CharlieLed
What I did was to fabricate mounting plates for all items that were to be mounted on the inside firewall and then used structural adhesive to mount them in place. In the photo below you can see, from left to right, the e-brake mount, the fuse block mount (long screws to fit the block), the MSD ignition box mount, gas pedal, and the Vintage Air mount. All these items are mounted to the firewall and yet none of the mounting hardware shows through the firewall and is visible from the engine compartment. The black coating on the floor and inside firewall surfaces is LizardSkin.
Old Aug 19, 2015 | 01:54 PM
greenmachine55's Avatar
greenmachine55
Bobbytnm and Rimrock F1....very very nice and clean! Where did you purchase the wire harness?
Old Aug 19, 2015 | 08:05 PM
Rimrock F1's Avatar
Rimrock F1
Mine came from Ron Francis. It is their Bare Bonz harness.
John Wall
May 26, 2018 04:21 PM
jniolon
16
Mar 3, 2018 08:19 PM
ExPACamper
Sep 5, 2016 08:07 PM
funone46
Jun 26, 2008 01:43 PM
bradoemba
20
Dec 1, 2005 02:34 PM
