Solder tips
Old Aug 19, 2015 | 11:35 AM
3twinridges's Avatar
3twinridges
Solder tips
We are starting to work on our wiring on the old truck, getting back to the original cloth wiring harness and good soldered connections/heat shrink instead of the crimp on type/bare wire deal. I picked up a good Weller iron at Fry's that should work well, but how about solder type?
I am thinking a good Rosin Core Solder 60/40, but should I go with lead or lead-free with silver. Which one would give the best connection and hold up the best?
JB
Old Aug 19, 2015 | 12:06 PM
jonf's Avatar
jonf
rosin core for soldering
Old Aug 19, 2015 | 01:06 PM
oldmerc's Avatar
oldmerc
oldmerc
Use small dia. rosin core solder for electrical work
Old Aug 19, 2015 | 01:13 PM
3twinridges
With lead or with silver?
Old Aug 19, 2015 | 01:56 PM
jack orchard's Avatar
jack orchard
60/40 rosin core. You are correct.,...jack
Old Aug 19, 2015 | 02:30 PM
raytasch's Avatar
raytasch
Believe Nothing
I doubt if you can even find solder with lead any more.
Old Aug 19, 2015 | 02:37 PM
ALBUQ F-1's Avatar
ALBUQ F-1
It's really only for domestic water piping that lead is banned.
Old Aug 19, 2015 | 02:51 PM
jack orchard
Not True
It is readily available. Try Amazon. Best place is a flea market or a swap meet. Usually $1 for what is left of a one pound roll. Just make sure it is clearly marker 60/40 Rosin core.,...jack
Lead-free should be used for any water pipe project.
Old Aug 19, 2015 | 03:34 PM
3twinridges
I bought some this morning, but they also had lead-free with silver. Would rather use silver if it works ok?
Old Aug 19, 2015 | 03:54 PM
mustangmike6996's Avatar
mustangmike6996
How are you at soldering?
Just make sure that you dont have any cold solder joints.
If splicing a wire, ensure a good mechanical bond prior to soldering for durability.
Old Aug 20, 2015 | 08:33 AM
ZOOT's Avatar
ZOOT
Silver is an excellent conductor but it heats up fast and is more brittle than the others. How are you heating the solder ? An electric soldering iron would be my first choice. My 2 cts.
82_F100_300Six
24
Mar 16, 2023 08:35 PM
b4hntn
1978 - 1996 Big Bronco
Dec 7, 2009 11:27 AM
RangerTuff05
Feb 19, 2008 09:52 AM
fords_forlife
Jul 1, 2006 10:40 PM
fordblue_ca
Electrical Systems/Wiring
Feb 14, 2004 04:16 PM
