Starter circuit issues
Old Aug 15, 2015 | 10:45 PM
wetbiker's Avatar
wetbiker
Hello guys
I have a late 04 f250 w the 6.0. When I try to start the truck w the key, it revs a bit then kicks the starter out. If i jump the starter wire to the battery it cranks fine. Ive swapped relays and it does the same thing. I took the relay out and jumped the switched wire to the starter wire coming out from the fuse panel under the dash and it cranks fine w the key. Something in the fuse box causing the problem? Anybody seen this before?
Thanks
Shem
Cooter126
Apr 22, 2017 06:35 PM
bigtruckmoose
Oct 19, 2011 10:53 AM
Akfortyniner
May 24, 2009 11:23 PM
shawngibbons
May 3, 2009 09:50 PM
