1959 Hood
Old Aug 14, 2015 | 10:42 PM
SeaCarr's Avatar
SeaCarr
1959 Hood
Hood weighs a ton. Has anyone come up with a solution?
Old Aug 15, 2015 | 12:24 PM
capterik's Avatar
capterik
Solution to what?
Old Aug 15, 2015 | 01:35 PM
Eye-Opener's Avatar
Eye-Opener
I just wish there was an alternative to the hood hinge/spring...
Old Aug 15, 2015 | 02:05 PM
SeaCarr's Avatar
SeaCarr
Solution to having two people to lift the hood.
Old Aug 15, 2015 | 03:14 PM
78_f800crewcab4x4's Avatar
78_f800crewcab4x4
Solution is to lubricate moving parts. Hood should pop open and lift with light force.
Old Aug 16, 2015 | 01:41 PM
spurredon's Avatar
spurredon
The bottom of the hood springs also wear into the bottom edge of the hinge and effectively reduce the tension on the springs making the hood heavy to lift. You may have to remove the springs, fill in the notch cause by spring wear and reinstall the spring. Also, give them healthy lubrication as already mentioned.
Old Aug 16, 2015 | 08:48 PM
GB SISSON's Avatar
GB SISSON
Aren't there 3 notches to choose from?
Old Aug 17, 2015 | 02:18 PM
Eye-Opener's Avatar
Eye-Opener
Mine has wore in a bit up top and the lower is on the third notch already. It moves very easily and isn't a binding issue....just a 500 pound hood on 56 year old springs...and this truck has been shown for the past 20 years so....some modifying will help. I'm also going to look at adding a lift support as in the newer cars if I can find the right pivot points that will do what I need and not be in your face..if I make it happen I will surely make a thread on it!!
Old Aug 18, 2015 | 05:14 PM
spurredon's Avatar
spurredon
Mine wouldn't even stay up by itself untill I filled the wear notch in, now it lifts as it should.
Old Aug 18, 2015 | 09:58 PM
OldMathGuy's Avatar
OldMathGuy
I've considered fabbing up a pair of struts as well.......it's on my long list of things on the to-do list. Lifting the first 4-5 inches is the hardest part....then not a problem.
BigBlueCat
Jun 26, 2012 01:14 PM
airwick51
May 13, 2008 02:22 PM
41Clay
Oct 9, 2002 11:09 PM
twr
Apr 14, 2001 07:50 PM
