Removing lift issues.
Old Aug 14, 2015 | 09:15 PM
Brian0075's Avatar
Brian0075
I have a 04 f250 6.0. I am removing my 6" Superlift. Besides being on for 11 years and building up on rust I am having an issue with removing the rear blocks. Not really with the removal but with the results. Before I put the lift on the rear was level, with the lift on it was level, but after removing the rear blocks I have found that that the truck now is shorter on one side. There is a notable difference, like 1/2 to an inch. Could I have moved something and note noticed it? If so what would that might be? Can it be corrected? Thank you in advance.
Old Aug 15, 2015 | 08:01 AM
Jmoen7's Avatar
Jmoen7
Continue looking at both sides to see if anything is different from one to another, pretty much like a spot the differences puzzle. How are the springs looking? Is one side softer than the other? What about the bushings?
Old Aug 15, 2015 | 06:11 PM
lupuseven's Avatar
lupuseven
Drive it around hit some hit some speed bumps in a parking lot and then see where it settles. Sometimes when a lift goes on it settle right until its driven. possible same when removed.
Old Aug 18, 2015 | 04:06 PM
Brian0075's Avatar
Brian0075
Thanks guys I will try those things and see what happens
swampsuperduty
Offroad & 4x4
18
Apr 18, 2012 08:59 PM
Big_Dom
Sep 9, 2010 02:20 AM
dieselstroke
Jul 12, 2004 10:36 PM
carbine 1
Jun 14, 2004 08:58 PM
jdawg78
Aug 1, 2002 09:10 AM
