Brakes Binding?
Old Aug 14, 2015 | 07:02 AM
Mbizzal's Avatar
Mbizzal
Brakes Binding?
1996 F250 single cab, two wheel drive. With ABS.
I noticed the other day that both of my front rims were very hot to the touch. Rears are cool but the fronts are hot. The truck doesn't seem to get down the road as quick as I think it should.
I live in the hills of Georgia so I used a small grade to test the breaks. Put the truck in neutral to see if the truck moves of not. It does move but I don't know even if the brakes are binding that it would stop the truck from moving.
The strange thing is that both wheels are hot. I had a caliper get stuck on my Jeep but it was just one, not both. So the questions begin.
Could a bad proportioning valve cause the front brakes to bind?
Is it likely that both calipers would be bad at the same time?
The break fluid is a bit black. Could flushing the fluid for new help with the brake calipers to return to rest?
As always I appreciate any insight anyone can give.
Old Aug 14, 2015 | 09:54 AM
Freightrain's Avatar
Freightrain
Could be the rubber lines are bad and not allowing the fluid to return. They fall apart inside, causing a "flapper valve" action. Allowing fluid to go one way, but not the other and thus holding the brakes on.
Could be both calipers too? Just have to pull it apart and see.
Old Aug 14, 2015 | 11:28 AM
oldone1942's Avatar
oldone1942
Watch this, pretty good tuto, and there is a bunch more.
Old Aug 14, 2015 | 11:33 AM
oldone1942's Avatar
oldone1942
93 F350 had the same prob, turned out to be the guide pins bound up.
Happy wrenching!
Old Aug 14, 2015 | 01:53 PM
Mbizzal's Avatar
Mbizzal
Sounds good. I will check the pins as soon as I can.
Any advice on checking them? Look for free movement when the brake is applied?
70T351W
Mar 14, 2016 03:31 AM
Buyerz
13
Feb 28, 2016 06:28 PM
RJB71
Oct 9, 2014 12:29 PM
Madmaxz
Jan 30, 2011 12:15 AM
87f1504x42001
Sep 9, 2007 01:14 PM
