Bronco II Ford Bronco II
1990 Bronco II issues
Old Aug 13, 2015 | 01:23 PM
jchandler11's Avatar
jchandler11
I have a 2.9 liter Bronco II that has some lingering issues. Recently the truck will start to buck and lose power on right turns only. Any thoughts? Also the battery seems to be getting drained. I recently replaced the alternator and also the alternator belt. The alternator belt will squeal and won't charge up to the half way point until about 30 minutes driving the bronco. I also noticed that with the power windows, lights on, etc it seems to drain it. Any thoughts. I need the truck to be a lot more dependable.
Old Aug 15, 2015 | 04:55 PM
87 XLT's Avatar
87 XLT
If this is the same as my 87 the positive battery cable & 4 fuse links are connected together at the starter relay.One fuse link is charging voltage from the alternator, the other 3 power everything on the truck. Make sure the connection is clean & tight.
Then start it up & start wiggling wires under the hood & see if you can get it to cut out.
75_92_95
1978 - 1996 Big Bronco
Jul 14, 2011 10:03 PM
ErrorS
16
Dec 29, 2010 03:58 PM
Inksma
Dec 14, 2006 04:18 PM
88BroncoII
Electrical Systems/Wiring
Aug 7, 2004 04:56 PM
markhschmitz
Aug 21, 2002 08:56 AM
