Bronco 2 Electrical/Starting Problem
Old Aug 7, 2004 | 12:22 PM
88BroncoII's Avatar
88BroncoII
Cool Bronco 2 Electrical/Starting Problem
88 Bronco II. When truck sat for a week. The battery went dead. Jumped it and it ran and started fine. Truck sat for 4 days, bateery was dead again. Bought new battery and during replacement, I connected the positive connector to the battery, and then the negative cable. When I connected the negative cable, a green wire that was connected to the solenoid/relay on the fire wall started smoking. Now nothing works. No gauges, no radio, no courtesy lights. Nothing...
Help!
Old Aug 7, 2004 | 03:15 PM
Franklin2's Avatar
Franklin2
See if you can find fusible links "C", "D", and "E" shown in the diagram at this link:
http://www.autozone.com/images/cds/g...3d800f947a.gif
If "C" is burned out, I would suspect there maybe something wrong with your alternator. The alternator being bad would also explain the mysterious draining of the battery too.
Old Aug 7, 2004 | 04:56 PM
88BroncoII's Avatar
88BroncoII
Thanks for the help. It was the fusible link "C". I replaced it with a 20 amp in-line fuse holder and will replace the alternator.
