Quick header install question
Old Aug 13, 2015 | 07:51 AM
chesster51's Avatar
chesster51
Was thinking about installing the headers this weekend and after looking at the stock manifolds they use 3 studs on each side to support dipstick and coil bracket on driver side and intake support arm on the passenger side. Are you guys going back with studs in these locations to have attachment points for the brackets or doing something else? Is the support bracket for the intake necessary? Would like to get this figured out before starting.
Old Aug 13, 2015 | 08:38 AM
Conanski's Avatar
Conanski
The intake support isn't needed, I didn't replace it on mine when swapping engines and it went the rest of it's life without any issues. The coil bracket and dipstick I modified to be supported off the valve cover studs.
Old Aug 13, 2015 | 09:58 AM
chesster51's Avatar
chesster51
Thank you sir.
Old Aug 13, 2015 | 01:47 PM
fordboy97's Avatar
fordboy97
I did the same as conanski, worked good. The passenger side also support the air pump lines but I deleted all that stuff anyway
EllieMae94
Oct 18, 2017 07:55 AM
BiggPoppa
1978 - 1996 Big Bronco
May 18, 2017 09:41 PM
94OldBlue302
Exhaust Systems
Aug 13, 2015 07:35 AM
linckeil
Aug 26, 2009 01:49 PM
Cheap Monster
May 25, 2004 12:41 AM
