I have a '94 with a 351w. I had to remove the long coil bracket when I installed headers as I could not get a stud to fit without rubbing. Does the coil bracket act as a ground or only for support?
I like that idea. Looks like the coil and bracket is mounted sideways using the the TAB/TAD mounting studs. And the EGR solenoid is moved back and up using it's original bracket? Yes, I was also able to fit a stud for the oil dipstick and the intake support bracket on the other side, just not enough room by the #7 header tube for coil bracket. Your engine bay looks fantastic btw. How are the DEI header wraps holding up?
