Intermittent battery light
It could be as simple as a corroded ground, a bad terminal connection, and bad positive connection on the alternator, a bad alternator, a battery that needs to have water added to the cells, a bad battery, etc.
There are sooooooo many reasons that can cause the light to come on.
Stewart
You can also get your battery load tested at a local auto parts store. Some of the quick lane shops will have these available as well so you don't have to remove the battery.
When does the light come on?
When my alternator was dying the light would come on at full throttle and my truck would fall on its face until I let off. Meaning the alternator was charging at idle but not under a load.
In addition to checking the connections also check the field control plug (the only plugged in wires on the alternator). I had one that was loose and so the alternator would intermittently cut in and out. Bought a replacement and the same thing happened. Finally figured out it was the darn repair guy and once I plugged it in properly everything worked.
