m5od grinding problem..
Old Aug 9, 2015 | 07:33 PM
chrisexplorer's Avatar
chrisexplorer
so i have a 93 ford explorer with an m5od 5 speed manual. i had the clutch t/o bearing and slave replaced about 8 months ago and all was good until maybe a month ago. it started to grind when putting it into first. it stopped for a while, and it started back up again even worse. noticed my fluid was a little high so i drained some and it went away. now today it started again, except now it will grind in neutral if i have my foot on the clutch. it will go away as soon as i lift my foot off the pedal and give it some gas.
so basically now it will do this in neutral, foot on the clutch, rolling, stopped. it will also grind when im moving, clutch applied in gear. the grinding will go away when i lift my foot off the pedal or give it gas, in all scenarios where the grinding starts
it doesnt do this ALL the time. usually when its hot and its been restarted, and sometimes it will only happen when double pumping the clutch when starting in 1st to 2nd, but goes away as soon as i gas it. the sound will start out slow, reach its peak within like 2 or 3 seconds, and *gas pedal* goes away. or press clutch pedal again and it goes away.
Old Aug 14, 2015 | 05:51 PM
steve(ill)'s Avatar
steve(ill)
when you push the clutch pedal in, you have a throwout bearing that lets the clutch spin on the input, and the transmission not turn on the output... Possibly the noise is not transmission grinding, but bearing noise on the throwout ??
I don't know about that specific transmission / bell housing, but some trucks use to have a grease zerk on the bottom of the throwout bearing in the bell housing. There was a 4 inch diameter hole in the bottom of housing, remove it and you can see the throwout bearing and possibly a zerk.. ???
Old Aug 14, 2015 | 05:52 PM
steve(ill)'s Avatar
steve(ill)
I tight pilot bushing can also make a whining noise, possibly sounding like a grind.
robs01f250
22
Nov 17, 2010 12:27 PM
JesterPgh
Feb 26, 2009 12:16 AM
Unimog005
Oct 19, 2007 08:00 AM
knocturnal
13
Oct 16, 2002 07:07 PM
jon69f250
Apr 5, 2002 10:00 PM
