Sponsored by: Real Truck
Climate Control
Old Aug 8, 2015 | 03:31 PM
Sellian's Avatar
Sellian
Climate Control
Having issues with my 11 f-250 6.7 and the climate control. When it is hot outside and I first turn on the truck (with the key and not remote start) and the climate control is set to auto with both sides calling for a low temperature, it will alternate warm and cold air and also constantly switch from floor to dash to vents with no real consistent pattern. It will do this while driving in town as well but seems to correct itself when traveling highway speeds. I don't believe it is a cooling issue because it will freeze you out when it is working correctly. Also, when I checked it out at an idle while it was acting up, the compressor never shut off. I am assuming it to be a sensor of some sort but wondered if anyone had experienced similar issues before I take it to a dealer.
Allstar recovory
Oct 23, 2013 11:55 AM
alfie623
2009 - 2014 F150
Jan 1, 2013 08:49 PM
Jimax
6.7L Power Stroke Diesel
13
Jul 11, 2012 08:08 AM
BigFord74
May 9, 2008 07:27 AM
BSMART27
2004 - 2008 F150
Nov 15, 2005 12:18 AM
