Hey all it's been awhile since i've needed any help. Not sure if that's good or bad. But i have a small problem i hope.
The other day it got a little cool out so i preceded to turn the temp up on the control and all i'm getting is cold air. Tried to use the heater manually and still cold air outta all modes Defrost floor doesn't matter. I do get heat to the back vent's. I figure it's something not switching over on the front end.
Is there anything i should check before taking it to the dealer's and having warranty look at things?
keep us posted. i had the same problem and all it did was turn the dial back and fourth a couple times and then it got hot. happened a couple of times. not in about 1 month. but, just to clarify, you do hav e the manual a/c controls right??
I had the same problem when I bought my ex used.They said it was a diode not sure if that is the right part name but that is what the dealer called it. It must have been easy because it only took them about 1/2 an hour to fix and now it works great.
