climate control?
Old Nov 12, 2005 | 06:02 PM
BSMART27's Avatar
BSMART27
climate control?
I have an 05 screw lariat w/climate control and no matter what i have the temp set at the a/c automtically comes on and never goes off. Anyone know wha the deal is?
Old Nov 12, 2005 | 06:35 PM
ATCS2004's Avatar
ATCS2004
This is normal operation. You can shut it off manually, but it isn't necessary.
Old Nov 13, 2005 | 09:54 PM
ReForder's Avatar
ReForder
I find it annoying that the A/C comes on automatically like that. It particularly annoys me that on the manual system, the defroster and defroster/floor setting also calls the A/C into action, even if the dash light isn't illuminated. I can hear the compressor go on. Just kind of silly to drive around in the winter with the A/C running in the background.
Old Nov 14, 2005 | 04:15 PM
Litre1's Avatar
Litre1
A/C dehumidifies the air, thus making the defroster more effective.
Old Nov 14, 2005 | 04:29 PM
BSMART27's Avatar
BSMART27
A/C also makes the gas needle go down alot quicker also.
Old Nov 14, 2005 | 04:32 PM
Litre1's Avatar
Litre1
True, but won't you lose the same amount of gas or even more when you have to idle twice as long waiting for the window to defog?
Old Nov 14, 2005 | 05:22 PM
GordoPanocho's Avatar
GordoPanocho
Just trust that Ford knows what they're doing and move on. Change can be good sometimes.
Old Nov 14, 2005 | 11:56 PM
ReForder's Avatar
ReForder
I know how it works, just don't know why they couldn't give you the option to disable the A/C after the defroster has done it's job. It gets a little too toasty with the panel/floor vents selected, in order to keep the A/C from chewing gas unnecessarily, say on a chilly but dry 40 degree day. Even without the A/C light on, the compressor is active, you can hear it.
Old Nov 15, 2005 | 12:18 AM
ford390gashog's Avatar
ford390gashog
well look at it like this the a/c pump consumes about 6 hp at its most. you lose more in parasitic loss than the a/c pump uses. so i would not worry and the a/c pump is pretty quiet.
CRobertson
May 27, 2013 10:43 AM
96f150
1997 - 2003 F150
Sep 24, 2012 01:31 PM
mrimike
2004 - 2008 F150
May 16, 2010 03:10 PM
lew52
2004 - 2008 F150
Mar 28, 2010 06:41 AM
