P0325 code on 2006 Expy
Old Aug 8, 2015 | 12:43 PM
Domino's Avatar
Domino
SIL's 06 Expy (5.4l) has a code P0325 (knock sensor) Anyone have experience or advice repairing this ??
Thanks !
Old Aug 8, 2015 | 12:58 PM
Skauber's Avatar
Skauber
I replaced both knock sensors on my '05. From what I understand is that these rarely go bad, and it's most of the time a wiring issue. On mine, it was actually a wiring issue in the sense that some idiot in the vehicles history did a "repair" or something, and actually cut the wire on both knock sensors, and taped in some jumper between the harness connector.. Really weird. Replaced both with new, and the engine was a lot happier with its life after.
The original ones from Ford is manufactured by Bosch, so instead of buying a Motorcraft part at $34, you can get a Bosch one at $19. If you're going in there to replace it (you need to remove the intake manifold), I'd replace both sensors even if you're only getting a code on one, and I'd replace the CHT sensor in the passenger head. Also, inspect the heater pipe, it likes to rust and break. Mine wasn't too bad, but I sanded it and the engine block down a bit and hit it with heat resistant paint just to help it along a little.
PirateGhost
Modular V10 (6.8l)
Feb 14, 2019 05:38 PM
j2007
Aug 16, 2011 08:04 PM
rkymtnrider
2004 - 2008 F150
Jan 7, 2011 08:15 PM
cdj98f150
1997 - 2003 F150
Feb 20, 2006 02:40 PM
alan911sc
Jul 20, 2005 05:53 AM
