Ball Joint Replacement
Old Aug 8, 2015 | 05:31 PM
KDAVID1's Avatar
KDAVID1
Originally Posted by CPB1
What's the part numbers for the kits you have and the tool
Where did you get em? Can't see them good on my tablet.
Old Aug 8, 2015 | 06:13 PM
TooManyToys.'s Avatar
TooManyToys.
Old Aug 8, 2015 | 06:54 PM
KDAVID1's Avatar
KDAVID1
That's what a needed. Can search from there. Main thing is the tools I have now for that kinda stuff isn't big/stout enough for the f350 so I gotta stock up.
Old Aug 8, 2015 | 08:25 PM
TooManyToys.
Stock up for possibly a one time use? If I were you I would get the snap ring pliers as they are a lifetime useful tool if you do a lot of mechanical work. When I did my ball joints eight years ago I made my own seal installer with Home Depot pipe for about $12 and in my shop facility I already had the ball joint press that you can borrow from Advance or Autozone (one is better then the other). Today if I would need to do this again it would be at home and I would just need to borrow the press from the store.
Here's the continuing thread on the subject. If you haven't seen it.
https://www.ford-trucks.com/forums/3...ll-joints.html
Old Aug 8, 2015 | 09:22 PM
Yahiko's Avatar
Yahiko
Well so much for starting this job today.
I was at Autozone picking some cotter pins. And I just don't feel like it.
Sean
6.0L Tech Folder
KDAVID1's Avatar
KDAVID1
Thanks for the link. I like to own my own tools. Too inconvenient to "borrow"
I get more use then just my stuff out of them (once I have them) I'm not against making the install tool either but buying will probably be better for me for it that's for sure
Old Aug 8, 2015 | 09:24 PM
KDAVID1's Avatar
KDAVID1
I think that's rain?
Old Aug 8, 2015 | 09:50 PM
Yahiko's Avatar
Yahiko
Yuppers.
I really did not want to do it anyway. I do need to go change my oil.
It's only 1500 over due.
Sean
6.0L Tech Folder
Old Aug 8, 2015 | 10:13 PM
CPB1's Avatar
CPB1
I don't think anyone has made the tool for the 05 and newer trucks, there different. Not saying it can't be done though.
Old Aug 8, 2015 | 10:17 PM
TooManyToys.
I'd like to have rain. Our rainfall here in nj is at 10% of normal for the last 4 weeks. We have trees that have leaves turning yellow and dropping. Even 40-50 ft with tap roots next to wetlands.
I thought on one of the other forums the thread was modified for the newer hubs.
Old Aug 8, 2015 | 11:11 PM
87crewdually's Avatar
87crewdually
Originally Posted by Yahiko
Yuppers.
Sean
6.0L Tech Folder
1500 miles over? Shame on you.
U can't beat having your own tools. Also the ball joint press is multipurpose and can be used for u joints too.
Old Aug 8, 2015 | 11:14 PM
78fordman's Avatar
78fordman
Otc does make a vac seal install tool for the 05 and new trucks
Old Aug 8, 2015 | 11:16 PM
  #28
78fordman's Avatar
78fordman
I would also use xrf ball joints. Million mile warrenty, and they seem to hold up in the Dodge front ends, something no one else seemed to be able to do. Impact and at least a map gas torch. Heat is key to getting that stuff apart.
Old Aug 9, 2015 | 12:04 AM
  #29
Yahiko's Avatar
Yahiko
No heat or impact. Just a good bath in Kroil and let soak in a few days.
Sean
6.0L Tech Folder
Old Aug 9, 2015 | 12:58 AM
  #30
King-bRanch's Avatar
King-bRanch
Well I don't need to help here cause Chuck (who helped me) has posted everything including Tool #'s
I was foolish & didn't order the 7750 Plier Set upfront, then of course could not get it apart & had to wait till Amazon got them to me (very nice Pliers)
Also I had debated between XRF & Raybestos, ended up going Raybestos (Ball-Joints & Hub's) but I will say this.... I would NOT buy them again, had an issue & Raybestos were very crappy on phone & would not help. Luckily Amazon stepped up to the plate & yes I left a Review for Raybestos on Amazons web-site.
I'd go XRF & don't forget the 7750 Plier's
