Let there be light...
Old Aug 9, 2015 | 02:55 PM
  #31
miihere24's Avatar
miihere24
Originally Posted by Tomahawk
I apologize for the poor quality of this post, I left out some details....it was Friday afternoon.
1- Blue/Yellow - Horn switch
2- White/Blue st. - to right front turn signal lamp
3- Green/White st. - to left front turn signal lamp
44- Blue - power from turn signal flasher
5- Green - to wire 282 right rear turn signal and stop lamp
9- Yellow/Black st. - to wire 283 left rear turn signal and stop lamp
10- Red/Black st. - power from wire 810 stop lamp switch to wire 284 Red from fuse panel
Cool!
Thank you! This will help greatly when I'm back. I probably could have followed the first post, but you're right, it was Friday afternoon....(:
Old Sep 2, 2015 | 09:50 AM
  #32
TeachNlive4ever's Avatar
TeachNlive4ever
Well?
and bumping to the top
Old Sep 3, 2015 | 07:44 AM
  #33
miihere24's Avatar
miihere24
Hey, I haven't forgotten about this. Things have been crazy.
Lots and lots of rain and while I enjoyed playing in the hose, doing electrical in the rain doesn't appeal to me. (:
Plus I was hit by some idiot driver while in my other car and want to make sure I'm 100% before crawling around on the floorboards.
I'm hopeful to fix it up this month; fingers crossed!!
Old Sep 3, 2015 | 08:03 AM
  #34
TeachNlive4ever
Ahite, you only have 27 days left. Make it happen.
Old Sep 3, 2015 | 08:07 AM
  #35
mjunk1's Avatar
mjunk1
Bummer about being hit but glad you are ok. My turn signals stopped working yesterday. I replaced the flasher that is dangling under the dash to no avail so now I have to start digging as well. I'm going to have to stop saying I hate electrical problems. It must be like praying for patience - anytime you do it you get thrust into the middle of things you don't want in order to develop yourself.
Old Sep 3, 2015 | 08:11 AM
  #36
TeachNlive4ever
10-4 on praying for patience, That's right up there with "expand my territory"
There are 2 flasher fuses. the other may still be clamped to the back of the cluster as in its original location.
Mii, do forgive my narrow mindedness. I'm happy your not injured as well.
Old Sep 3, 2015 | 09:27 AM
  #37
miihere24's Avatar
miihere24
Thanks! Let the count down begin...
I'm also in the process of wiring up additional dash cameras into the daily drivers. I had just a few weeks ago put one in one car to test it out and see if I liked the set up - only to then be hit in the car that didn't have a dash cam. Just my luck.
Tell me more about these flashers...I did see the...big flasher fuse, but assumed (like one shouldn't do) that it was just for the hazards. I had to replace the dash cluster so I'm wondering if this second flasher fuse behind the cluster might also be part of my problem; not having blinkers or brake lights.
Old Sep 3, 2015 | 09:58 AM
  #38
TeachNlive4ever
Many moons have past and many barley pops have been consumed sense my last run about with this issue. one flasher should be in a "U" clamp under the dash, the other should be behind the cluster plugged into the plastic housing.
As you know, the blinker assy, brake light switch, flashers and even the bus fuses all work togehter to complete or break the circuit as it may be.
Old Sep 3, 2015 | 11:15 AM
  #39
JEFFFAFA's Avatar
JEFFFAFA
1st...I also am glad you are OK. Metal can be replaced.
Usually when there are two problems ya gotta find what they have in common. If the fronts light up but not the rears then look what the turn signals and brake lights have in common in the rear. If no bueno all over then look at the turn signal switch. The brake lights go through it also. Does your T/S lever feel loosey goosey? Then that's prolly it.
Old Sep 3, 2015 | 01:15 PM
  #40
TeachNlive4ever
Speaking of playing in the hose, wasn't there a pic request from someone?
Old Sep 3, 2015 | 01:22 PM
  #41
JEFFFAFA's Avatar
JEFFFAFA
Ha Ha. You just got another title in The Kingdom.
Old Sep 3, 2015 | 02:31 PM
  #42
TeachNlive4ever
uh ohh, better go look for that one.
Old Sep 3, 2015 | 02:44 PM
  #43
qman's Avatar
qman
Ya, from me. About 6 times. So far nada.
Old Sep 28, 2015 | 11:30 AM
  #44
TeachNlive4ever
2 days left in this month... Just sayin
Old Jan 14, 2016 | 12:32 PM
  #45
miihere24's Avatar
miihere24
I am SO far behind. I feel like this was just a couple weeks ago. I hope y'all had a great holiday! We had some major flooding here in SC and then I personally has some more from broken pipes. It's been crazy.
I finally have the part and plan to work on it next week. These posts will be VERY helpful.
I got the blinkers working correctly, but still don't have any brake lights. I went ahead and got a new brake light switch along with the cam that was suggested.
It almost looks like the brakes are engaged when I pull the headlight switch, would that be possible? I guess we will find out.
Would it be terrible to just connect the wires directly instead of using the plugs?
Mustang65432
Sep 25, 2010 04:01 PM
Galizien
Oct 3, 2006 03:29 PM
packrat56
13
Apr 6, 2004 06:31 AM
jasonvt
Bronco II
Aug 21, 2003 12:23 AM
