Let there be light...
Old Aug 7, 2015 | 04:08 PM
qman's Avatar
qman
hahahahahaha . . . like a fake one
Old Aug 7, 2015 | 04:09 PM
Tomahawk's Avatar
Tomahawk
Originally Posted by qman
I don't think you should be thankful of this. The steering wheel should not come out pretty easy. Every time I take mine out and put it back in I need a puller to get it back out.
Am I right on this guys or am I tightening mine too much when putting it back?
I have to use a puller every time.
miihere24's Avatar
miihere24
Originally Posted by Tomahawk
The area you want to look at is between the "WINDSHIELD WIPER & WASHER SWITCH" and the "IGNITION SWITCH" that's the turnsignals. I don't know why it's not labeled. For the brake lights look for wires 810, 810A, 282, 283, 284.
The turn signal switch is wires in the column are 2, 3, 44, 5, 9 & 10
I how this helps.
If you turn on the wipers and the horn blows, you've had too much beer.
Haha. I'm gonna need less beer to follow these instructions!
Old Aug 7, 2015 | 04:11 PM
miihere24's Avatar
miihere24
That's what I thought too, but I mentioned this once before and someone called me lucky.
I would call me a bit unlucky at the moment.
Old Aug 7, 2015 | 04:14 PM
qman's Avatar
qman
I think he probably meant that you were lucky to not be dead yet. I don't think you want your steering wheel coming off while driving.
Old Aug 7, 2015 | 04:17 PM
Tomahawk's Avatar
Tomahawk
All you need is a voltmeter or test light in one hand and a beer in the other and start checking wires.
Wow, it's getting close to.......
Old Aug 7, 2015 | 04:25 PM
miihere24's Avatar
miihere24
Ha. Well, the steering wheel is definitely on there good. Though I guess I could check to see how good. I remember I only had to remove one nut, but when watching a video it acted like there were more...my mind is drawing a blank.
A test light I definitely have. I guess I know what I'm doing this weekend.
Old Aug 7, 2015 | 04:59 PM
JEFFFAFA's Avatar
JEFFFAFA
While that would be ideal, his shop is about 40 minutes away and I would undoubtedly be pulled over half a dozen times. Not to mention he's also the one that couldn't diagnose my overheating issue and without even looking at it you all did it via online!
Do you mean I should get this one?
More Information for OE PRO SM41F
No. That is for mid year 69 and older. Go to www.dennis-carpenter.com and buy this:
Loading zoom..
Zoom
<table class="table table-striped table-boxed"><tbody><tr class="odd"><th>Make</th><th>Model</th><th>Body Style</th><th>Notes</th><th>Year</th></tr><tr><td>Ford</td><td>Truck</td><td>F-Series</td><td>- </td><td>1969-72 </td></tr></tbody></table>
Review Summary
Our Low Price:$29.95
Turn Signal Switch
1969 - 72
D0TZ-13341-B
No Reviews
Be the first to review this product
  • From Serial #G30001 F100-350
StatusIn Stock
Sign In to Add to Wish List Add to Cart
Quantity
.imgBox:hover { -moz-box-shadow: 0 0 10px #ccc; -webkit-box-shadow: 0 0 10px #ccc; box-shadow: 0 0 10px #ccc; }
Old Aug 7, 2015 | 05:14 PM
TeachNlive4ever's Avatar
TeachNlive4ever
Miihere, do you have an aftermarket steering wheel? After market will just unbolt. If its factory, ya might want to put some extra beer bicep on that center bolt.
If you are going to replace the pre assembled cam with connected wires, the wires SHOULD be color coded to your truck harness as well. Separate the plug and with a jewelers screw driver or ice pick (assuming your allowed to play with sharp objects...) in the plug going to the cam there is a "tang" that you'll press in and remove each individual wire.
You did the rad., this will be a cake walk.
Old Aug 7, 2015 | 05:50 PM
miihere24's Avatar
miihere24
Thanks for directing me to the right part!
It's not an aftermarket steering wheel, but it's zero wiggle to it sooo hopefully it's not going anywhere.
Ha. Sharp objects yes, fire no. (:
I found a couple videos online so I think I have got the idea. Radiator seems much easier than this.
Old Aug 7, 2015 | 05:59 PM
miihere24's Avatar
miihere24
I went out and had a look and it doesn't look like the whole turn signal cam with wires was replaced. The ones in there now look a bit worse for wear.
I was also going to buy the new connector for this reason. Is this the right connector for the cam:
Turn Signal Switch Connector - Male | Dennis Carpenter Ford Restoration Parts
Old Aug 7, 2015 | 07:18 PM
JEFFFAFA's Avatar
JEFFFAFA
I about fell off my chair. I copied and pasted this on an email to all my friends and some customers. Bwa-ha-ha!
Old Aug 8, 2015 | 09:15 AM
  #28
qman's Avatar
qman
I bought that DC switch a few years ago and the pins were too big to fit into the harness plug so I had to just connect them without the plug. If you buy that thing let me know if the pins fit the plug.
And it was the new DC switch that had the terminals touching one another.
Old Aug 8, 2015 | 11:38 AM
  #29
miihere24's Avatar
miihere24
I most certainly will. I have to go out of town so it will be a week or so. I'm still going to check the terminals on the current one.
Did you buy the new plug for it and the pins didn't fit? Or you mean the pins didn't fit the plug you already had?
Old Aug 9, 2015 | 12:43 PM
  #30
Tomahawk's Avatar
Tomahawk
I how this helps.
I apologize for the poor quality of this post, I left out some details....it was Friday afternoon.
1- Blue/Yellow - Horn switch
2- White/Blue st. - to right front turn signal lamp
3- Green/White st. - to left front turn signal lamp
44- Blue - power from turn signal flasher
5- Green - to wire 282 right rear turn signal and stop lamp
9- Yellow/Black st. - to wire 283 left rear turn signal and stop lamp
10- Red/Black st. - power from wire 810 stop lamp switch to wire 284 Red from fuse panel
Cool!
