Planning some much needed R&R
Been putting off some needed maintenance on the old girl. Plans are to do the following:
Lower pipe gasket
Lower radiator hose
Glow Plugs (motorcraft)
UVCH if needed
Turbo pedestal o-rings
Riffraff plenum inserts
Riffraff HPX
EBPS Cleaning
Anything else you guys would suggest (or discourage) while I have things apart?
Oil Cooler?
Torque injectors?
Injector o-rings?
Regulated return?
Truck has ~153,000 on it
Lower pipe gasket
Lower radiator hose
UVCH if needed
Riffraff HPX
EBPS Cleaning
Oil Cooler?
Torque injectors?
Injector o-rings?
Regulated return?
The Riffraff FRX is a good $ alternative to a full regulated return. You might get Clays Front ABS Grease-able Block Off Fitting.
scottm1
04-14-2017 02:44 PM
thompson2112
11-06-2012 07:21 PM
kornfanjoe
07-26-2012 04:32 AM
gunwalder
13
03-21-2005 08:47 AM
