Planning some much needed R&R
Been putting off some needed maintenance on the old girl. Plans are to do the following:
Lower pipe gasket Lower radiator hose Glow Plugs (motorcraft) UVCH if needed Turbo pedestal o-rings Riffraff plenum inserts Riffraff HPX EBPS Cleaning Anything else you guys would suggest (or discourage) while I have things apart? Oil Cooler? Torque injectors? Injector o-rings? Regulated return? Truck has ~153,000 on it |
The Riffraff FRX is a good $ alternative to a full regulated return. You might get Clays Front ABS Grease-able Block Off Fitting.
