Not too sure who might be able to help, but I have the MPG MAX water meth kit installed on my 2004 F350 6.0... (part # 50015)
From what I gather in the instructions the MPG mode has a start point and a MAX point , where the operator will set a starting point (say 10psi) and a max point (say 20psi) where the controller will vary injection rate until it hits 20psi, where 100% inj rate is achieved...
Then after that there is the POWER MODE, where a second stage or nozzle can be utilized to inject a higher percentage at a specific boost point (say 25 psi)...
Since the 100% injection rate has already been achieved in the mpg mode, should the power mode already be at 100% to achieve maximum performance? Or does the kit automatically re adjust and ramp up as needed?? How do i have control of where the POWER MODE is injecting 100% at a specific boost point?
I cant remember what the kit or the controller did before as it has been a while since i had used MPG mode (I have been towing lots)...
I would contact Snow. I have been curious about the water meth injection for awhile myself but haven't seen too many using it. I'd be curious how it does on thw 6.0.
Me 3.
Other than forgetting the things how is it working out for you?
