New to me '97 F350
Old 08-03-2015, 07:23 PM
mechmagcn's Avatar
mechmagcn
mechmagcn is offline
New to me '97 F350
Hi guys, just bought a '97 F350 PSD with 305K on the clock. Its just a rough ol work truck, been rode hard and put up wet. I bought it not running for $200 bucks, so there's really no way I can get burned.
The PO told me that the truck was running well and just shut off going down the road. Looks like someone has been working on it because the fuel lines were loose from the regulator and the RH HPOP line was loosened. Replaced all this and dropped in a fresh battery, crank but no start. Checked fuses and found all of the big ones good, but a 25A smaller one blown. Replaced and it started trying to hit. Finally got it started using a little brake cleaner as starting fluid (it works well without being as hot as ether). After the air cleared out it idled well but would cut out severely when reved. Now if I shut it down it is difficult to start, it will crank over and hit occasionally and finally start, but surge and smoke until I rev it slightly. It will even out and idle well but still cut out if revved above 2K rpms.
The engine seems to be pretty well worn, it has extreme blow by. Someone installed a small K&N lookalike filter on the elbow before the turbo and a hose dropped down for a blow by tube. When idling it will look like the truck is on fire.
Not sure where I'm going with this truck, probably just parts for a '97 F250 4X4 PSD I already own.
Old 08-03-2015, 08:05 PM
97-psd's Avatar
97-psd
97-psd is online now
With that much smoke I would suspect the injector o rings.
That is a heck of a price for the truck
Old 08-03-2015, 08:09 PM
mechmagcn's Avatar
mechmagcn
Thanks! The guy started out at $1500, but it had been sitting in a field for over a year, so I started talking him down. It helps that I work on logging equipment for him too. ;-)
Old 08-03-2015, 08:14 PM
Action4478's Avatar
Action4478
Action4478 is offline
An easy test would be pull the IPR & look at the small O ring
Old 08-03-2015, 08:39 PM
mechmagcn's Avatar
mechmagcn
After thinking about it a while, the truck evidently had some mods done. There is a bung welded into the DP for a pyro, the resonator and muffler are gone, so there's no telling what I will find when I dig deeper.
Old 08-03-2015, 08:41 PM
mechmagcn's Avatar
mechmagcn
That was going to be my first thing to check.
Old 08-03-2015, 09:30 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
$200!!! What a deal!
Old 08-04-2015, 08:05 PM
LeoJr's Avatar
LeoJr
LeoJr is offline
Very first thing I would do is go to Ford (not the local parts store) and get a CPS. If that doesn't solve most of your problem then keep the original in your glove box along with the 10mm socket and ratchet you used to change it.
If it does solve most of your problems, throw the original away, keep the same tools in your glovebox, and at your first convenience, get another one from Ford.
There are two kinds of 7.3 owners in this group...those with a spare CPS and tools in there glove box and those that without.
$200? Even for a parts truck that's great!
And you likely already know, at 399,999 the odometer on these turn back to 300,000.
If you do part it out there is a frame crossmember I'd like to get from you.
Old 08-05-2015, 01:21 AM
jonathan.e.green's Avatar
jonathan.e.green
jonathan.e.green is offline
Huh? Really!?
Old 08-05-2015, 06:31 AM
mechmagcn's Avatar
mechmagcn
Was not aware of this, really?
Old 08-05-2015, 08:00 AM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
MOOSE_MACHINE is offline
yes sir. Mines at 451 but reads 351
Old 08-05-2015, 08:23 AM
mechmagcn's Avatar
mechmagcn
OK, so there's really no telling how many miles are on this truck. With the condition I was wondering if the speedo had been inoperable for a while.
I currently run a 95 Dodge 3500 for a service truck. When I bought it the PO told me the speedo hadn't worked in years, probably had over 350K on it, all that was wrong was the wires were unplugged. Just don't understand folks that let little things like that go......
Old 08-05-2015, 09:15 AM
nossliw's Avatar
nossliw
nossliw is offline
Sheesh for 200$ I would have drove a 1000 miles to pick that up! Great find man!
I agree on the CPS if its cutting in and out. I'd also look at those injectors as they probably are long gone as well, let alone the orings. Do a compression test and see how bad it truly is before you give up on the motor. I have seen quite a few of them appear to be on fire at a light and will still tow the wheels off anything.... I have yet to make the true correlation between blowby and lack of compression. I have seen it go both ways.
Old 08-05-2015, 10:27 AM
madpogue's Avatar
madpogue
madpogue is offline
Look at your odometer next time you turn the key to RUN, and all the digit segments light up at once. It'll illustrate why this happens.
Old 08-06-2015, 09:29 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Quick Reply: New to me '97 F350
