Just my luck. Coolant problems
Old Aug 1, 2015 | 07:24 PM
Jeff heine's Avatar
Jeff heine
Drained and flushed real good.
Went to Ford dealer. Parts man asked the mechanic " just plain green and water, nothing special"
Went to second dealership. Bought motorcraft, premium antifreeze and additive. Asked twice if this is for the 7.3. He said yes that's what I was told.
Three days later water pump starts leaking. Drain it all change pump. Buddy called, who also has a 7.3. He said I got a great mechanic. He says only use the red antifreeze in a 7.3???????
Old Aug 1, 2015 | 08:44 PM
oldbird1965's Avatar
oldbird1965
Old Aug 1, 2015 | 10:03 PM
BBslider001's Avatar
BBslider001
There's your sign...er, stuff. (Said to dumb Ford guy)
Old Aug 3, 2015 | 09:26 AM
Jeff heine's Avatar
Jeff heine
Awesome. I'll get some thank
Old Aug 3, 2015 | 06:18 PM
Jeff heine's Avatar
Jeff heine
I got the fleet guard, its made by peak. Says premixed, requires no water
Old Aug 3, 2015 | 06:26 PM
Jeff heine's Avatar
Jeff heine
I finished the water pump yesterday afternoon. Disconnected the heater hose coming out of the water pump and ran it until it was clear. Flushing all the antifreeze out. Drove it today, with those water, no leaks, all is good. I tried to drain the block this evening. There are two plugs in the area of the oil filter. One accepts a 1/4" drive. I used a 3/8 x 1/4 adapter. It aint budging, adapter started to twist in the plug. The other is an odd size, between a 1/4 and a 3/8. What do you suggest?
Old Aug 3, 2015 | 06:27 PM
Jeff heine's Avatar
Jeff heine
Hose water
Old Aug 3, 2015 | 08:40 PM
oldbird1965
Its pre-mixed with SCA, not water.
The plug above the starter is a square head bolt.
The other I couldn't get out either so I pulled the heater coil.
Old Aug 3, 2015 | 11:39 PM
Jeff heine's Avatar
Jeff heine
It says sca precharged.
Old Aug 4, 2015 | 10:04 AM
madpogue's Avatar
madpogue
Fleet Charge comes in two forms. BOTH are pre-CHARGED with SCA, which is the anti-cavitation additive. One is pre-DILUTED, one is full-strength.
Similar to any other anti-freeze, one form is full-strength, meaning you should mix it aprx. 50/50 (or a little stronger) with DISTILLED water. The other form is already a 50/50 mix, i.e. pre-DILUTED with water. The second form is more convenient, but waay more expensive, because you're effectively buying more water at almost the price of the anti-freeze itself. So it's ultimately cheaper to buy the full strength, and bottled distilled water. Another reason to buy the full-strength is that, even after flushing multiple times and draining the block from both drains, and the radiator, and pulling the lower hose, and the heater core, heater hoses, etc., there's STILL some water left in the system. So if you use the 50/50 pre-diluted, your final solution will be somewhat weak. If you put in four full gallons of full-strength after flushing/draining, then top up with distilled water, you know you have a good 50/50 solution.
The kicker is, you have to check the label carefully. The label pictured above is long obsolete. The new labels for the two formulas (full strength and 50/50 premix) are almost identical.
VaFordman26
16
Nov 9, 2015 04:49 PM
1979kent
Jun 29, 2012 09:17 PM
Adamswd
Mar 21, 2012 02:07 PM
88f150302
16
Apr 4, 2009 10:46 PM
mcallister
Mar 23, 2008 06:40 AM
