drum brake issues
Old Aug 1, 2015 | 12:47 AM
Eaglesfan796's Avatar
Eaglesfan796
drum brake issues
Ok so me and my dad replaced my drum brakes on the back of my 94 150 and it gave us nothing but hell.. once we finally got them in place the drums didnt want to fit on so after many swear words and flying tools my dad slammed them on using his legs.
All was fine and good but recently im hearing an ungodly screatching noise comming from the back of my truck. I cant help but think its something in my brakes back there.
So.i guess my question is had anyone else has the problem where your shoes dont wanna let your drum go on or have any of you had the same issue with an ungodly screatching comming from the back? If so was it the brakes or something else?
Also i bought my pads from Pep boys and im thinking maybe thats my issue.. i dont have much faith in their parts (and i work there) where else should i buy?
Old Aug 1, 2015 | 07:08 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Noise started after replacing the shoes. Sounds like it's time to pull the drums and see if a spring popped off. It's possible that the parts were wrong (didn't you compare them to what you removed?) but usually it has something to do with the shoes not being adjusted correctly if the drum won't go on. Using the drum brake tools helps immensely when removing/installing the springs.
Edit: pads are for disk brakes, shoes for drum. Terminology matters.
Old Aug 1, 2015 | 07:13 AM
f31951truck's Avatar
f31951truck
If the drums would not fit, make sure the adjuster on the bottom was turned all the way in. If they still won't go on after that, your parking brake could be stuck due to frozen cables not allowing the parking brake to retract. Also verify correct parts as mentioned before. Good luck.
Old Aug 1, 2015 | 09:51 AM
Eaglesfan796
We adjusted them so they were as closed as possible. Yes i did compare and they were the same aside from the amount of shoe.
Thanks ill have to look to see if a spring came loose
Old Aug 1, 2015 | 09:53 AM
Eaglesfan796
Thanks we adjusted it all the way in and it still wasnt working. The parking brake wasnt frozen so that isnt it ill have to try again with different parts.
Old Aug 1, 2015 | 10:20 AM
Tedster9's Avatar
Tedster9
Take some pictures and post them here.
Old Aug 1, 2015 | 10:36 AM
Eaglesfan796
Alright once i take it apart ill do that probably wont be for a few days
Old Aug 1, 2015 | 11:56 AM
My4Fordtrucks
[QUOTE=Eaglesfan796;15541872]We adjusted them so they were as closed as possible. Yes i did compare and they were the same aside from the amount of shoe.
Thanks ill have to look to see if a spring came loose[/QUOTE
They were the same but different? What "amount of shoe" are you referring to?
Fastback460
Apr 15, 2014 08:28 PM
GregonVI
Oct 29, 2012 09:13 PM
ericdes
1983 - 2012 Ranger & B-Series
May 30, 2011 07:50 AM
metalskater2
18
Apr 7, 2010 09:13 PM
chewyjackson
Feb 28, 2007 08:34 PM
