Modular V10 (6.8l)
Cranks but doesn't start.
Old Jul 31, 2015 | 07:20 PM
stonecold0469's Avatar
stonecold0469
Hello guys. I'm Rafa, I'm new here and arrived because i need some help.
I've got a 2011 e-350 6.8L V10 with 189.XXX miles.
I had to change the headgaskets because it overheated and now the van won't start.
-Front of the van is not installed.
-Cranks but doesn't start.
-Checked for spark, none was found.
-Fuel is present.
-With my scan tool checked for engine speed (rpm) and that was 0.
-The last thing i checked was voltage to the crankshaft position sensor plug which revealed 0 voltage.
I had to leave cause it was late and the van is at a friend's house.
Any help on this? I have limited time to work on it. Help is greatly appreciated. Thanks in advance!
Old Aug 1, 2015 | 08:09 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Connect a digital volt meter set to AC volts, and check the output voltage from the crank sensor when you crank the engine. If you don't get anything, the sensor is either bad, or not close enough to the "tone ring" to get a signal.
There will be no voltage at the crank sensor plug, the PCM doesn't supply any to the sensor itself. The sensor is like an ABS brake sensor, it will send a signal back to the PCM, so do the above, and report back
Old Aug 1, 2015 | 08:15 AM
stonecold0469
Thanks for the response.
I verified that the ring is clean, not broken and is facing front. The sensor itself i did not remove or cleaned it. I will try this in a few minutes and let you know.
Old Aug 1, 2015 | 08:21 AM
krewat's Avatar
krewat
By the way, you should see probably at least .1 volts, maybe .2-.3 at the sensor when cranking.
Old Aug 1, 2015 | 08:23 AM
stonecold0469
I will let you know asap.
Is there any way that the van won't start because of the front not being installed? Happened to me in my mazdaspeed 6.
Old Aug 1, 2015 | 08:32 AM
krewat's Avatar
krewat
I really don't know. If all the engine wiring is connected, then theoretically it should just run.
All the engine grounds are connected?
Old Aug 1, 2015 | 08:34 AM
stonecold0469
Yeah, it has like 6 or 7 grounds all conected. Maybe I'll have to get a wiring diagram for the crank sensor to see if it somehow is connected to the front.
Old Aug 1, 2015 | 04:09 PM
stonecold0469
Hello again.
Found out the issue. Apparently the last owner did have something to do with the crankshaft sensor harness.
After taking the covers of the harness apart, the plug itself was left hanging in my hand. The truck fired right up after soldering the harness!!!
I'm so happy!
Thanks also for your help!
Old Aug 1, 2015 | 04:32 PM
krewat's Avatar
krewat
EGGGGSSSSELLLENT!
Let us know how the rest of it turns out, OK?
therigwelder
1983 - 2012 Ranger & B-Series
Aug 2, 2019 07:28 PM
raptor2005
Jan 20, 2013 03:30 PM
dasio
Sep 25, 2012 09:26 PM
copuntryboy
1997 - 2003 F150
Mar 19, 2012 06:17 AM
dangrv
Modular V10 (6.8l)
16
Sep 1, 2009 12:58 PM
