2.3 crank sensor
Old Aug 2, 2019 | 07:28 PM
therigwelder's Avatar
therigwelder
2.3 crank sensor
I’ve been working on a no start issue on my 93 ranger 2.3l. on another post I talked about my ICM, I have moved past this as the problem for my no start. upon piercing the blue wire coming out of the top connector of the ICM leading to the crankshaft position sensor and while cranking the engine the sensor only pulses at 6 volts. Does this confirm the position sensor is bad? Also curious the ICM was bad so was this the cause of sensor failure?
QwkTrip
13
Sep 10, 2007 10:16 AM
pwrstk01
Feb 15, 2006 08:38 PM
geoaigel
Jan 10, 2005 10:50 AM
TommyH
Jul 31, 2004 09:58 AM
