Light power mods, head work
Old Jul 30, 2015 | 05:27 PM
idiguy90's Avatar
idiguy90
I'm getting new guides seals and getting valves ground. Some had a 1/2 inch of play. After that gasket set. I'm doing a spectre cold air intake so I'm wanting to turn up the pump like 1/6 of a turn. Is that a flat? Any info on that? And no I don't want to "roll coal" I figured with cai and a straight pipe it it would help the power to move some more fuel with the new air flow. Is cutting up the muffler the best way to make a straight pipe? Sorry kinda new to diesels any help would be appreciated!
Old Jul 30, 2015 | 09:48 PM
7threeaz's Avatar
7threeaz
Yes that is a "flat". I separated my exhaust right at the first bracket from the front of the truck and put a turndown on it. That and a custom intake are the only mods I have so far and I turned up my pump 2 flats, runs clean only a little smoke at full throttle.
In addition I'll say what most everyone else will, get a pyrometer before turning up your fuel so you can monitor your temps.
Old Jul 30, 2015 | 10:23 PM
PlumCrazy7's Avatar
PlumCrazy7
don't waste your money on a cai, put it towards a turbo kit. Straight pipe will help some but a turbo is the biggest bump in power.
Old Jul 30, 2015 | 10:39 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
is the engine out of the truck? if so,why not grab a torque cam from Russ? that'll make her pull harder than over fueling an n/a.
camshaft for the IDI: "The torque cam" Typ4
Old Jul 31, 2015 | 01:57 AM
Macrobb's Avatar
Macrobb
Basically, yeah. All of the above.
As far as how much you can turn up the pump, it's basically 'until it smokes'. Once you get smoke, you get slightly /less/ power than turning it down to just before that. And when it's smoking, you get high EGT temps, not good for your valves.
Old Jul 31, 2015 | 06:48 AM
idiguy90's Avatar
idiguy90
Yes the engine is on a stand. I'm interested in that cam. Heard a lot of good things about Russ. Anyone here ever use that cam?
Old Jul 31, 2015 | 11:39 AM
RacinNdrummin's Avatar
RacinNdrummin
Hands down this.
Biggest bang for the buck is a turbo kit, and then you bolt stuff like cold air intakes and such on down the road...
RacinNdrummin
You ever run one?
Old Jul 31, 2015 | 11:41 AM
RacinNdrummin
Its a good N/A cam and works well with turbo's with a slightly smaller hotside. Russ's truck performs well with his cam and his setup.
Old Aug 1, 2015 | 02:53 PM
Romel77's Avatar
Romel77
Do we have a dyno of that cam? I am just curious, because it is so glorified over several threads and I have not found an actual dyno of it, although there was a great effort to do it in the thread posted by FordF250xlt. Butt dyno is not acurate and sometimes feels what we want to feel. Just saying.
Old Aug 1, 2015 | 03:27 PM
hairyboxnoogle's Avatar
hairyboxnoogle
The dyno showed the torque to come in 200 rpm sooner and also fall off sooner than stock if i remember right. I think its a good low end cam. However if i were going turbo i would run the stage 1 without a doubt, improvement over stock on both sides. Justin has a custom NA cam based of the 302HO cam but i dont know if he is selling it yet or still testing.
Old Aug 1, 2015 | 03:48 PM
Romel77's Avatar
Romel77
YesI know about the new Justin´s cam, waiting for numbers, when meeting my needs I go for it.. I do remember of one dyno comparison of the torque cam and the stage 1, if my memory serves me right. However if I remember corectly the stage one was superior over the rpms the torque cam was not that flat at all, it did have a better torgue a bit down low but droped premature during rpms with a curve not very consistent. Maybe a bad record.
Old Aug 1, 2015 | 04:43 PM
hairyboxnoogle
Also during that test there were innumerable anomalies, different pumps, turbos, gear ratios etc etc etc.
Kingkong0192
34
Jul 29, 2014 04:13 PM
idahoturbo94
May 18, 2010 12:49 PM
Big_red78
Jun 7, 2007 05:27 PM
Mr. Bob
Jul 18, 2006 01:32 AM
1978fordf250
13
Feb 12, 2006 01:01 AM
