please help
Old Jul 28, 2015 | 05:47 PM
Curt Hurst's Avatar
Curt Hurst
Angry please help
1987 ford f250 4x4 460ci, will not start or if it does it dies 30 seconds later. new carb, coil,efi unit. it has duel tanks so both fuel pumps cant be bad. 99k on truck it was running great shut it off and boom. looking for help and or ideas please..
Old Jul 28, 2015 | 08:01 PM
bashby's Avatar
bashby
Carbed engine should have one mechanil fuel pump.
Old Jul 28, 2015 | 08:04 PM
Curt Hurst's Avatar
Curt Hurst
fuel pumps in gas tanks x2
Old Jul 28, 2015 | 08:07 PM
Bradslab's Avatar
Bradslab
You can start by narrowing it down. Does it lose spark or lose fuel?
Old Jul 28, 2015 | 10:18 PM
Curt Hurst's Avatar
Curt Hurst
looses fuel, timing is good , pour gas down carb and it runs
Old Jul 29, 2015 | 06:28 AM
mtrosclair's Avatar
mtrosclair
Stuck float valve in new carb? Kinked fuel line?
If it'll run fine when you shoot some carb spray or starting fluid down the cafrb then its a fuel problem, maybe check for flow at the carb and go from there?
Old Jul 29, 2015 | 07:19 AM
Curt Hurst's Avatar
Curt Hurst
no fuel is getting to the carb or to the filter
Old Jul 29, 2015 | 09:30 AM
rla2005's Avatar
rla2005
IIRC your carbed truck uses an oil pressure switch in line with another relay to only energize the fuel pump relay when the engine is running. Subford has a diagram somewhere here.
Old Jul 30, 2015 | 09:05 PM
Curt Hurst's Avatar
Curt Hurst
thanks IIRC I will try that.
Old Jul 31, 2015 | 07:21 AM
rla2005's Avatar
rla2005
Found it:
From this thread: https://www.ford-trucks.com/forums/1...ave-power.html
Old Jul 31, 2015 | 03:21 PM
Dflynn926's Avatar
Dflynn926
I had to replace both my pumps in my 88F250 efi, both went within 2 hrs, well the gauge aspect. It was more so preventative.
Moral is they can both go relatively close time frame...
But I am also really unlucky like that.
cardude59
May 12, 2011 01:00 PM
RangerHaywood
Jun 8, 2010 07:29 PM
91gettaDI
Sep 4, 2009 09:34 PM
dave1985
1983 - 2012 Ranger & B-Series
Jun 30, 2008 06:44 PM
Capt_Dunzell
49
Sep 17, 2003 07:24 PM
