1987 f-250 dual fuel pump, fuel pumps don't have power
I have a 1987 f-250 custom 460 motor with dual tanks and i don't have any power going to my fuel pumps or my selector switch I've replaced my relays and checked all my fuses and still don't have any power does someone know what else it could be?
well when I crank the starter I get power to the switch but when I turn the key on without cranking I don't get any power I cant hear the fuel pump priming or any thing I have power to the relays but none going back out so I thought it would have been the relays so I replaced them and still nothing
so i wont get any power at all to the selector switch or fuel pumps until i crank the motor over even when i just turn the key on and don't crank the motor
If you need power temporarily, to test with the ignition on and the engine off, jumper the plug connected to the oil pressure switch located behind the EGR valve.
