88 2.3l surging idle
Hey I bought a lil ranger today. Is runs okay for a four banger. the engine idles Ina rhythmic fashion. The distributor housing is loose and I can adjust the idle speed with turning it. I set it to idle about 800-1000 and it sounds better. How I prevent it from turning loose again?
Also the throttle is pretty stiff where is a good place to lube?
Repair history is that the TPS was malfuctioning and the EGR wasn't building vacuum, I assume it's been fixed correctly.
Are there any otherthing else I should check knowing that I just bought the truck.
Thanks everyone
Thanks everyone
JEOL
02-09-2008 06:34 PM
