Modular V10 (6.8l)
Code P0713 Help
Old Jul 26, 2015 | 10:44 PM
hernC's Avatar
hernC
4wd Low
Code P0713 Help
My 2010 F 250 V10 with 119,000 miles is showing Code P0713. I see that it is for the trans temp sending unit but can anyone tell me what are the signs and symptoms for this code? It started with the trans temp gauge not working and then it started to shift bad i.e. it feels like it slips and then jerks when shifting gears. Could the bad sending unit cause the shifting problems? Is this a common problem with this year?
Old Jul 27, 2015 | 08:28 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The sensor is inside the pan.
Symptoms of a bad sensor is first the gauge stops working, then usually the shifts get bad. It will also set a P0713 code. It's a pretty common problem with all years of the TorqShift transmission.
Old Jul 27, 2015 | 01:58 PM
hernC's Avatar
hernC
4wd Low
Thanks a million! Going to Ford dealer to pick up part.
V10-XXL
Oct 26, 2015 02:04 PM
Fordclevor
1983 - 2012 Ranger & B-Series
Apr 20, 2015 10:26 PM
savagefan
May 9, 2014 04:58 AM
After Hours Auto
Dec 17, 2010 05:29 PM
