stock shock ?
Old Jul 25, 2015 | 10:53 PM
bigblueexcursion's Avatar
bigblueexcursion
stock shock ?
I am thinkin of doing the v code front leaf spring with an add a leaf. For the rear I am thinking of a 4" block. Will the stock shocks work? I will eventually get some rancho 9000's but cant afford them yet. Also I wil be installing a hellwig antisway bar, do I need longer sway bar end links? I have a 2000 ex with the v10. Currently I have 285 tires but want to go to 315's. Thanks for the help
Old Jul 26, 2015 | 01:23 AM
Bently_Coop's Avatar
Bently_Coop
Lifting with stock length shocks will not work. Not sure about the helwig though. I beleive they are some what adjustable.
Old Jul 26, 2015 | 06:50 AM
wpnaes's Avatar
wpnaes
I think you'll be ok with the stock shock up front. I did the same with my V swap up front with a 'level kit' until I got $ for the Ranchos (used the stock size Rancho 9000).
Old Jul 26, 2015 | 07:14 AM
WE3ZS's Avatar
WE3ZS
BigBlue, Welcome to the EX forum and family!
As far as your desired spring swap/lift I have a couple of questions for you.
How much lift are you looking to end up with from this over stock?
Why a V code with an Add-A-Leaf vs X codes? How much extra lift and spring rate will the AAL add? A V code swap should yield about +1.77" of front ride height over stock, a W code will lift about +2.77" an X code will give about +2.90". Each one has a higher spring rate which will firm up the ride along with the extra height. Lift shackles will add height while keeping the same springs and ride feel.
How much rake (rear ride height vs front ride height) do want to have when completed?
Adding a 4" block to your current 2" stock block (not recommended) or swapping the stock 2" for a taller 4" block?
Do you or do you plan to tow with this EX? If so, what kind of trailer and weight? What gear ratio does this EX have? The V-10 makes it's best power at higher RPMs so it likes deeper gears, 4.30 is a very nice ratio for towing with these motors. Taller tires (315's = 35"-ish tall vs the stock 31.5" tires) reduces the effective ratio to a numerically lower ratio, so if heavy towing is also in your plans give some thought to gear ratio changes with taller tires. Another consideration with towing heavy is that the stock rear springs on these wagons are prone to axle wrap under load, any increase in leverage with taller blocks will only make that worse. Stronger rear springs from a Super Duty pickup will be a better setup for towing than a taller block.
If you are swapping in stock OEM springs from a SD pickup, then yes your stock shocks should be long enough. If going with the pickup springs AND extra leaves, (like I did) then you may need to look at slightly longer shocks to keep them from over extending in high articulation situations.
If you go from the stock 2" rear block to a 4" block then the rear shocks should also be OK length wise, unless you are doing some serious off road flexing.
If you are buying the current design Hellwig rear sway bar it comes with a set of very nice adjustable length end links, so you will be fine there, adjust to keep the bar ends parallel with the bottom of the frame.
Old Jul 26, 2015 | 10:08 AM
bigblueexcursion
Thanks for the replies. Tom, how much of a lift is on your ex? I think I want a 4" lift. I wouldnt mind a little bit firmer ride but I don't want a tank either. If I did the v codes and the shackles how much height would I gain? As far as rake I would like it level or just slightly lower in front. If I get the rear SD leafs would I still need a block? I want to clear 315/75/16 tires. I do pull a 6500lbs trailer. Right now I have 3.73 gears which I will change eventually to 4.30s.
Old Jul 26, 2015 | 11:33 AM
WE3ZS's Avatar
WE3ZS
Thanks for the replies. No problem, I'm always happy to help where I can.
Tom, how much of a lift is on your ex? My front is lifted 3 7/8" by modded X codes (added the top overload leaf from rear B codes). The rear is lifted 4.5" - 5" by modded B codes (added 2 bottom EX leaves, F-350 blocks and 2 sections of EX traction bar on each side.
I think I want a 4" lift. 4" is a good place to be for running 35" tires, my current tires are 35.28" tall and I do get a little rub on the front springs at full steering lock.
I wouldnt mind a little bit firmer ride but I don't want a tank either. I like a firm ride in a truck, and that was part of my goal in doing my spring swap as well as improving towing performance which it did very well! Stock front V-10 EX springs are C codes rated at 3680lbs (for the pair), V codes are 5200lbs, W codes are 5600lbs and X codes are 6000lbs. X codes are very firm but not harsh, subjective yes, but from the several members here with them not too bad.
If I did the v codes and the shackles how much height would I gain? The shackles adjust the distance between the truck's frame and the rear of the front springs, they come in various lengths. Over a certain point I think you have to also change over to dropped hangers for the front of the springs to keep pinion angles and alignment specs within proper range. But I think up to about 3" dropped shackles are OK, suppliers (and some of our members here) should be able to offer better help with this I have never used dropped shackles.
As far as rake I would like it level or just slightly lower in front. I think they look best slightly tail high too.
If I get the rear SD leafs would I still need a block? Yes, If you want to see some lift. Read up on the spring swap articles in the Tech Folders at the top of the Ex forum, TONS of great info in there!
I want to clear 315/75/16 tires. A spring swap using the correct combination of OEM parts will allow for enough clearance for those. There are few different ways to get the desired ride height increase, much of which is covered in the Tech Folders and we can discuss the option more here in the forum too. This is a great thread to see some measurements and what folks here have done to get their EXs where they wanted them. https://www.ford-trucks.com/forums/1...easurents.html
I do pull a 6500lbs trailer. OK, that is pretty much a "middle weight" trailer for these wagons and may be fine with the stock suspension if properly hitched and balanced. However with taller blocks used I think you would start to see some rear axle wrap with the stock rear EX springs. Most of my mods have been to improve towing performance with our long heavy TT, 41' and 11,000lbs. I'm very happy with the improvements so far and still have a few more on my list, but at this point it is a very reliable and comfortable puller.
Right now I have 3.73 gears which I will change eventually to 4.30s. If towing is in your plans as well as 35"-ish tires you may want to go to deeper gears to maintain an effective ratio in the 4.30 range. I went with 4.88 gears and my tires bring that effective ratio back down to 4.39.
Give some serious though as to exactly what you want to do with the EX and what kind of performance you want. We have members here that can jump in and help with all sorts of great advice, help and information. Many are also willing to get dirty spinning wrenched with you too, fill in your location in your profile so it shows in the upper right corner of each of your posts here, you might be close by one of your new EX friends!
Old Jul 26, 2015 | 05:06 PM
bigblueexcursion
thanks so much for all the helpful info
CrowneVic
Jun 13, 2013 08:00 PM
ExSKARsion
Sep 27, 2012 07:32 AM
MoreBoostPlease
Oct 31, 2011 08:11 PM
airjeff
Apr 22, 2011 11:43 AM
TeamMudd
Sep 8, 2010 07:09 PM
