Taking off lift?
Old Sep 26, 2012 | 07:22 AM
ExSKARsion's Avatar
ExSKARsion
Taking off lift?
Anyone familiar with how to reverse a lift and what I will need? My EX is currently lifted 10" but I'd like to just take it down to like a 2-4" lift. What is the best way at going about this?
Thanks for the help in advance!
Old Sep 26, 2012 | 12:04 PM
timf150's Avatar
timf150
Research the v/b moded code spring swap as that will get you to a 2" lift. If you want to go higher you can do the v/b codes with drop hangers on the front and a larger block on the rear or x codes in the front with the larger block in the rear.
I removed a large lift from my X back in April and here are the parts I needed to obtain in order to make it happen.
Here are the original parts I had to get first.
Stock pitman arm
Stock track bar bracket.
Stock sway bar end links
Stock shock brackets.
Stock rear leaf springs to Mod the B's
Stock rear block.
Things purchased new for the v/b setup.
New shocks
New front V code springs
New Rear B code springs
All new u-bolts and nuts
Rear sway bar -Hellwig
Tim M
Old Sep 26, 2012 | 12:09 PM
ExSKARsion's Avatar
ExSKARsion
Originally Posted by timf150
Research the v/b moded code spring swap as that will get you to a 2" lift. If you want to go higher you can do the v/b cods with drop hangers on the front and a larger block on the rear or x codes in the front with the larger block in the rear.
Stock pitman arm
Stock rear block.
New shocks
Tim M
thanks tim!!!
Old Sep 26, 2012 | 12:41 PM
timf150's Avatar
timf150
I should have added this thread.
https://www.ford-trucks.com/forums/1...l#post11802543
Tim M
Old Sep 26, 2012 | 02:06 PM
04fivefour's Avatar
04fivefour
you gonna sell the old lift?
Old Sep 27, 2012 | 07:32 AM
ExSKARsion's Avatar
ExSKARsion
I'm considering it, don't know how much I'd ask though. PM me if interested
BrianRich
Mar 22, 2018 10:50 PM
irockstar661
Mar 19, 2015 10:21 AM
rickdavis81
Mar 3, 2013 09:12 AM
zeenman1
May 2, 2011 06:40 PM
tacurt
Feb 5, 2010 07:12 AM
