steering problems
Old Jul 25, 2015 | 10:12 AM
Ole Green 66's Avatar
Ole Green 66
steering problems
I have a 1966 Ford F100, that I purchased in 1992. The problem is that the steering is real tight when you turn corners, hard to turn. The steering has a little slack in it. The truck had set up for 8 yrs when I purchased it. It only has 66,000 miles on this truck. What could be the problem, any info would be deeply appreciated.
Old Jul 25, 2015 | 12:45 PM
jowilker's Avatar
jowilker
Have you greased the front end lately, may be 6-8 fittings down there than need a little nourishment.
John
Old Jul 25, 2015 | 08:47 PM
yellodog's Avatar
yellodog
knock the steering linkage off the spindles, then try to turn the them. you'll probably find one or both tight. heat and grease, then check for play.
daves302
Apr 27, 2011 07:13 PM
mudslinging79
Bronco II
May 2, 2009 09:05 PM
Country705
Mar 15, 2006 06:31 PM
rogue_nine_2000
Mar 20, 2005 03:28 PM
