Up-pipe replacement/upgrade
Old Jul 25, 2015 | 07:00 AM
Zbugsii's Avatar
Zbugsii
I will be replacing my Y-pipe and up-pipe when I replace my turbo soon. I have the bulletproof EGR cooler and will probably keep it in place. But I have not found a good replacement up-pipe that has a better HD bellow than stock. I do not want to keep the stock bellow configuration on the up-pipe.
Anybody know of a good replacement?
Or can offer suggestions?
Thanks.
2004 F-350 crew cab long box, 4X4 Dually, Blue Spring, ARP Studs, Modified Heads with pressed in valve guides Bulletproof Water Pump, Oil Cooler, Oil Filter, & Amsoil Bypass Oil Filter, Aluminum Radiator, 4" SS Exhaust, Diesel Site HPOP, Coolant Filter, External Fuel Filter and transmission Filter, 2008 Tranny Pan and Filter, KC 1.5 Turbo, Helwig Swaybars, Dash Boss Monitor with Fuel Pressure and EGT, Evans Waterless Coolant, Jimmie Jammers, SS brake lines, Racor 4500 CCV
Old Jul 25, 2015 | 07:48 AM
npccpartsman's Avatar
npccpartsman
Contact bullitt390. He has a nice upgrade for the y-pipe at a very reasonable price.
Old Jul 25, 2015 | 12:02 PM
4x250cx's Avatar
4x250cx
my stock pipe let go around 115 k at the braided sections, both, I replaced it with a PPE it has no braided sections , just wrinkle belly ( what we call it on a boat ) there are no shields so I wrapped it with exhaust wrap twice where it goes by the ICP and IPR, its a nice looking piece, but time will tell, only got 20k on it now
Old Jul 25, 2015 | 06:07 PM
Zbugsii's Avatar
Zbugsii
I have found good options for the "Y" pipe, but I am looking for the "Up" pipe options.
So, if anybody can help with the up-pipe, please jump in.
Thanks
Old Jul 25, 2015 | 07:00 PM
KDAVID1's Avatar
KDAVID1
IPR makes a good one.
Just make sure to use oem hardware.
Old Jul 25, 2015 | 07:34 PM
Zbugsii's Avatar
Zbugsii
I went to IPR site.... I only see OEM Y and Up pipes and a straight through up-pipe that will not work with me still having EGR cooler.
I am still looking for up-pipe without the bellows, but with connection for EGR.
Old Jul 26, 2015 | 06:31 AM
npccpartsman
I fixed the spelling on Josh's handle.
FWIW--I've never seen an up-pipe with the EGR and no bellows, but I bet Josh can fix you up with a bellows that won't crack like OEM does.
Old Jul 26, 2015 | 01:19 PM
96_F250_Deezal's Avatar
96_F250_Deezal
I replaced my broken up-pipe with a Dorman pipe.
https://www.ford-trucks.com/forums/1...r-up-pipe.html
Old Jul 26, 2015 | 06:43 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Thanks for the shout out
As for a solid passenger up pipe that still utilizes the EGR cooler I haven't heard of it. Could be tricky lining up the manifold, cooler and y-pipe if it was all solid.
Avoid the MBRP Y Pipe. It's a complete joke. Seems the Dorman unit has an OK track history so far. Being that it's modeled after the OEM design I would expect failure at some point. And no that isn't a knock on Dorman, just the OEM flex joints are not the ideal solution for the 6.0.
Josh
VictorwithaC
Jan 15, 2018 08:17 AM
cj50
Apr 9, 2015 09:40 AM
locked up
Nov 3, 2014 03:04 PM
Big Red 5205
Nov 6, 2011 03:58 PM
Jayybird
Mar 5, 2010 09:47 PM
