1977 4x4 transfer case ?
Hmm.. As I don't actually have the truck yet I don't know when it was built. Nor can I look at the tag on the t-case.
I suppose I'll just ask the seller for the VIN number and whether or not he/she knows anymore details about it. The ad says "Ford '77 F 250 - 4WD, high boy edt.. Needs motor; 351 modified. $1,800 obo"
Does that seem reasonable? I should add that I am looking at another 1977 F-250 4x2 that has a good running 460 w/ auto in it that I would put into the 4x4 (hence my question about the divorced t-case).
Any thoughts or opinions on this would be more than welcome.
Thanks,
Steve
Thanks,
Steve
If it is in fact what afficiandos refer to as a highboy then it would be the earlier version with the divorced t-case. The very last highboy made with the desireble disc brake front end that was only made 1 1/2 years. Also the only one made with the 351m engine. Your 460 would bolt to the 351m bellhousing. It would still have to be a pretty nice truck to be worth $1800 without an engine. Ask the owner if it has a center drive shaft. That should clear it up on whether it is early or late.
77 1/2 they changed from high boy to low boy look for the front drive shaft that hangs very low in front if so that is a high boy it has three drives shafts 1 rear and two front low boy has 2 my 78 has np 205 case part time 4 wd which i belive most of them did from that year on
hope this helps
hope this helps
66with352
09-07-2016 10:52 PM
Savage Fabrication
15
07-08-2013 07:21 PM
Nick_F150
12-22-2008 03:53 PM
trouble
11-02-2000 03:07 PM
