frame bracing
Old Jul 23, 2015 | 06:43 PM
filthy6's Avatar
filthy6
frame bracing
I just put a 302 and AOD in my '56. Either had to, or chose to remove the cross member for the 292 and manual transmission I removed. I now need to see some examples of cross members. Will probably make one from scratch. Think I will need something to support the transmission as well as prevent the frame from torqueing. Thanks for any pics and/or advise.
Old Jul 23, 2015 | 07:11 PM
52 Merc's Avatar
52 Merc
As I'm sure you're aware, your new crossmembers should mimic the originals by connecting the top and bottom of the frame rails together to prevent the rails from twisting. Beyond that, it's simply a matter of building them in such a way that they don't interfere with the other workings of the truck, ie; exhaust routing, etc.
Old Jul 23, 2015 | 08:36 PM
Nicholas+'s Avatar
Nicholas+
Im getting ready to make one myself. To add to the above I would make the mount by the cab wings with a drop out so the trans can be removed later without pulling the engine if you ever have an issue.
Old Jul 24, 2015 | 03:11 PM
filthy6's Avatar
filthy6
Those are my thoughts also. At first glance it looks like the transmission mount is well back of the cab wings. Wondering if anyone found themselves needing a trans support as well as a cross member. My design skills are limited so I was hoping to just copy someone.
Old Jul 24, 2015 | 04:12 PM
jonf's Avatar
jonf
I kept the original cross member when we installed a SBF with an AOD. When we discovered that we couldn't take the trans out without pulling the motor we made a drop-out section in the original cross member. It was a PITA working under the truck but we were successful.
Old Jul 24, 2015 | 07:03 PM
filthy6's Avatar
filthy6
I suppose in hindsight I wished I had done it that way. My memory is for S*IT these days but it seems like it was in the way when I was trying to remove the rivets it shared with the front suspension hangers. Additionally I recall reading some posts where others thought it was necessary to remove it. Anyways now I have to do something to stop the bleeding.
Old Jul 24, 2015 | 07:15 PM
56panelford's Avatar
56panelford
I made this and it bolts back from once it came but doesn't hang down as low as the original. I also made the trans cross member as well.
Old Jul 24, 2015 | 07:31 PM
filthy6's Avatar
filthy6
Thanks for the information and especially for the pics. It looks like you left the frame mounted portions of the cross member in tact and fabbed up a bolt on center section. Am I seeing that correctly?
Old Jul 24, 2015 | 08:16 PM
56panelford
Yes you are, sorry , this pic is a bit blurry. I put alignment holes on each side to make it easier to bolt up, without the cross member just the weight of the cab starts to twist the frame rails.
Old Jul 25, 2015 | 02:25 AM
underthebridgejim's Avatar
underthebridgejim
FTE fan
John, you sure do beautiful work.
Old Jul 25, 2015 | 08:46 AM
56panelford
You do too Jimmy
Old Jul 25, 2015 | 09:24 PM
mustangmike6996's Avatar
mustangmike6996
I removed my stock trans crossmember and I need to gusset the frame and add some more bracing as well.
I used a universal Speedway crossmember for the trans. It bolts in but is not as strong as the stock crossmember.
I hope more people post pics here.
682bear
Jan 6, 2017 02:00 PM
underthebridgejim
15
Feb 17, 2013 07:42 PM
Old_Crow
Jan 10, 2010 11:12 PM
woodyf1
Oct 30, 2008 09:38 AM
create
22
Jun 7, 2006 05:34 PM
