Headlight Upgrade Guidance!
Old Jul 27, 2015 | 12:31 PM
exbxtoy's Avatar
exbxtoy
Originally Posted by Krazee Matt
As a matter of fact
You still have to cut the header panel. Which the way the original ad was worded when I bought them, you didn't have to - that was a load of crap.
If that's the style light you want, I would recommend the 05-07 housings with the matching header swapped in. While these are definitely better than the stock units, they leave some stuff lacking. The adjusters for a start, there is only one. Turning it out both raises the beam AND moves it out. Turning it in moves the beam down and in. There are no independent adjusters for vertical and horizontal. It took me forever to get the hot spots to be both where I wanted them for best light, while also not being that douchebag that's blinding everybody.
The beam pattern itself is somewhat scattered up close, which I didn't like. However I swapped 9005 bulbs into the foglights when I did the headlights, and they MORE than make up for the scattered pattern. I actually ended up jumping some wires in the switch to work my fog's independently from the headlights, so now I run the foglights only around town at night. Headlights for speeds over 45, below that the fogs are more than sufficient at lighting the road and shoulder.
If you want the LED's driving lights, I still suggest some 05-07 housings and get a quality halo kit.
One of my fog lights just burned out, so now I'm looking at upgrading them to a better brighter light. Are the 9005 lights that you are running LED?
Old Jul 27, 2015 | 01:35 PM
Krazee Matt's Avatar
Krazee Matt
Veteran: Navy
No, I'm just running some standard Sylvania Ultra (I think, orange packaging) bulbs. Haven't had a problem with them melting housings or wires and they been in there for over a year.
Having seen ags LED's, I'm going to swap out when I have some spare cash and see how they perform. Not saying what I have now isn't bright as all get out, but I like LED's for the lower electrical demands compared to incandescent.
Old Jul 27, 2015 | 08:22 PM
Bently_Coop's Avatar
Bently_Coop
On my 99 Super Duty I went with a 02-04 style head lamp and some Sylvania silverstar bulbs. Gray package. They are way brighter then before. If you need something brighter check out the link below for a projector kit and HID or LED setup.
The Retrofit Source Inc
Old Jul 28, 2015 | 10:20 AM
Alex F's Avatar
Alex F
Originally Posted by lonepalm
good video from 1A Auto on headlight replacement. Shows how to remove the clips that hold the lights in place. I manhandled mine out of there with needle nose pliers :-)
How To Install Replace Headlight and Bulb 99-04 Ford Super Duty F250 F350 1AAuto.com - YouTube
I installed these 99-04 Ford F250 / F350 / Excursion Euro Crystal Headlights With Corner - Bl, basically the oem look but smoked
Cool beans, thanks for the link!
Old Aug 4, 2015 | 04:38 PM
AppocAlexx's Avatar
AppocAlexx
I second this option. All the RetroFit stuff I have seen is amazing looking. Way better than any aftermarket assymblies you can buy and you can use FOMOCO headlight assymbly and have the best quality headlights IMO.
Old Aug 11, 2015 | 07:58 AM
nagetech's Avatar
nagetech
Thanks for all the ideas guys!
Is it my imagination, or is that retofit site not working right? I punched in my truck info, and it never gives me any options for headlight assemblies.
Jschon
25
Dec 23, 2018 03:31 PM
handifletch
Modular V10 (6.8l)
Oct 30, 2013 12:39 AM
chromy
Mar 14, 2009 10:55 PM
santacruzf250
Jan 23, 2009 07:30 PM
Docdor
May 7, 2008 12:42 PM
