Ford flash update
Old Jul 23, 2015 | 04:47 PM
Kdawg89's Avatar
Kdawg89
Ford flash update
Hello,
I don't know what calibration my truck has but is it worth taking it into Ford and and getting the latest software flashed or is the latest calibration not recommended? Truck is an 07 F350. Also what should I expect to pay for them to do this?
Thanks!
Old Jul 23, 2015 | 05:17 PM
WatsonR's Avatar
WatsonR
Around $150 and you probably have the latest crappy flash.
Old Jul 23, 2015 | 05:24 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
They will charge as it's no longer something that's costing them money.
Anyone with an SCT can tell you for sure, it doesn't matter if it's married or not.
If you're getting decent mileage, leave well enough alone.
Your flash can range anything from VXCF4XX (best fuel economy and power), VXCF5XX, or you may have VXCF9XX (the latest)
Old Jul 23, 2015 | 05:50 PM
WatsonR's Avatar
WatsonR
I've got an 04 with the latest flash mileage suxs until I put a tuner on it.
Old Jul 23, 2015 | 05:54 PM
Toreador_Diesel
From personal experience, the Atlas 40 works wonders for a tuned truck running a VXBC9XX flash.
Old Jul 23, 2015 | 06:33 PM
Kdawg89's Avatar
Kdawg89
I already have SCT tunes. I will hook my unit up and see what strategy the truck has.
Old Jul 23, 2015 | 08:38 PM
WatsonR's Avatar
WatsonR
Nice to know, just ordered an FICM tuner from PHP.
Old Jul 23, 2015 | 08:55 PM
evan1242's Avatar
evan1242
Ford flash update
I have VXAP2N2
Old Jul 24, 2015 | 11:51 AM
Kdawg89's Avatar
Kdawg89
Well I have VXCF9H7 which I guess is the latest flash so that answers that question! Thanks!
Old Jul 24, 2015 | 12:15 PM
2wdDezlX's Avatar
2wdDezlX
Does the strategy correspond with the ecm or ficm? When going with a custom tune like gearhead srl, is there any advantage to get the latest strategy or a certain version, or does the new tune override it?
Old Jul 24, 2015 | 12:42 PM
Toreador_Diesel
Originally Posted by 2wdDezlX
Does the strategy corispond with the ecm or ficm? When going with a custom tune like gearhead srl, is there any advantage to get the latest strategy or a certain version, or does the new tune override it?
The strategy corresponds to the PCM. FICM strategies are AMZ2AL11 or AMZ2AL12.
When getting a tune from Gearhead, they optimize whatever strategy you have. Sometimes it works great, sometimes it doesn't. It's been proven by PHP that the use of an earlier strategy nets better power and fuel economy than later strategies.
For exmaple:
VXBC6XX does better on fuel economy and power than VXBC9XX
VXCF4XX does better on fuel economy and power than VXCF9XX
If need be, you can be written back to an earlier strategy as long as the first 3 letters match.
For example:
VXBC9XX can be backdated to VXBC6XX
VXDB1MZ can be backdated to VXDA1M2
9 times out of 10 they hit the nail on the head, but sometimes either backdating or updating the FICM flash to the Atlas 40 helps.
Old Jul 24, 2015 | 01:05 PM
2wdDezlX's Avatar
2wdDezlX
That's what I was thinking but didn't know if it replaced the strategy or optimized it. I have 2 6.0 excursions, 1 03 and 1 05 with 04 motor. The strategy is different between the 2. VXAP2N2 and VXBC9NH. Should I have them send the tune with those or try to change them before hand? Thanks, for clarifying for me.
Old Jul 24, 2015 | 09:22 PM
Toreador_Diesel
Ford flash update
That's what I was thinking but didn't know if it replaced the strategy or optimized it. I have to 6.0 excursions, 1 03 and 1 05 with 04 motor. The strategy is different between the 2. VXAP2N2 and VXBC9NH. Should I have them send the tune with those or try to change them before hand? Thanks, for clarifying for me.
On the 05, try the Atlas 40 with the SRL tune from Gearhead. As I mentioned before, VXBC9NH plays well with the Atlas 40 ask Magnolia Tom. We found this to be true on his wife's 04 Excursion. If for some reason, it doesn't get better VXBC6 is your friend. Ask Misky6.0
Gearhead, innovative, and PHP can write you back to VXAM7N2. That was the original 2003 strategy that yielded the best power and fuel economy for the 2003 MY. The best thing about this strategy is that it uses the EBPS. The later strategies are inferred.
Old Jul 24, 2015 | 11:49 PM
Yahiko's Avatar
Yahiko
So sense we are talking what flash ****** is in the PCM
What would be the better one with this in a 2006 F350?
VXCF9H7
Also Bit thank You for the info.
Sean
Old Jul 25, 2015 | 06:28 AM
npccpartsman's Avatar
npccpartsman
VXCF9H7
Sean
VXCF4 is the best base flash for an 05 and up.
