front caliper piston material?
Old Jul 22, 2015 | 11:11 AM
mats027.3's Avatar
mats027.3
Does anyone here know if the factory front brake caliper piston material on an '02 excursion 7.3 4x4 is phenolic or steel?
Old Jul 22, 2015 | 11:59 AM
Archion's Avatar
Archion
Veteran: Marine Corps
IIRC, it's phenolic, Never seen a rusty piston on one.
Old Jul 22, 2015 | 12:03 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
I've always gone with the steel ones.
Old Jul 22, 2015 | 12:14 PM
BEARDOWN's Avatar
BEARDOWN
I go with steel on the front for my 2002. For the rears I can only find phenolic.
Old Jul 22, 2015 | 12:56 PM
mats027.3's Avatar
mats027.3
had one start taking a dump on my while pulling a camper through Yellowstone... 820miles from home.. was able to pull it apart compress it (eventually) and then get it moving but its dragging.. more or less ruined the Rt frt rotor but its not noticeable until I get into the brakes hard when unloaded. still pulls to the right. but made it home now time to tear it apart while I put new inner axle seals in.... neverending sometimes.. Note to everyone else.. if you put ball joints in you might as well pull the carrier and put new inner axle seals in while your at it..
jkalin99
30
Apr 25, 2018 09:08 PM
archangel
Oct 25, 2009 05:33 PM
crashbox455
Feb 22, 2004 11:27 PM
robjohn
Feb 23, 2003 12:31 AM
