Rear block change
Old Jul 21, 2015 | 11:43 PM
Watcher58's Avatar
Watcher58
Rear block change
I need to change my rear blocks. I know I have to take off my RAS and lower shock bolts. Anyone know if you have a Hellwig do you have to loosen it and remove from the axle?
Old Jul 22, 2015 | 12:18 AM
Bently_Coop's Avatar
Bently_Coop
Are you replacing blocks? Going to a larger size? or just removing all together?\
Edit: If you want the 4" blocks check out this thread. Keep in mind there are two different part numbers based off chassis length.
https://www.ford-trucks.com/forums/6...ar-blocks.html
Old Jul 22, 2015 | 07:49 AM
Watcher58's Avatar
Watcher58
I'm changing from the standard 2 inch blocks to some 3 1/2 inch F 350 blocks I have. I went v code in front. Keeping my rears since I have RAS and a Hellwig. It's just a little down in the back--maybe 1/2 inch or so
Thanks for the link!
dh1200
Aug 17, 2016 06:16 PM
cinvest1
Jan 30, 2014 08:18 PM
kysuperduty
Jul 27, 2008 03:22 PM
monty0
Sep 3, 2007 11:27 AM
Tjdb2000
May 10, 2005 12:28 AM
