need help understanding mode 06 test data
I am running ScanMaster-Elm 2.1 on my windows 7 laptop using an ELM 327 scanner. No CEL or codes come up on the scanner.
Initially when connecting with mode 06 (Monitored Test Results) I am only seeing misfire data at a very low rate on cylinder one. If I let it run then I am seeing $56 counts rise up and left long enough will trip a fail. I think $56 has something to do with total misfires but not really sure how to read that data or what to make of it. I have downloaded Ford's OBD2 manual for this year and it doesnt help much in this area.
I swapped COP from cylinder 1 to cylinder 5. Still got the exact same data as before so I cleared all codes using the scanner. Cylinder 1 went to zero but $56 still counts up like before. I am going to reset the computer by unplugging the battery and then taking it for another drive. Then rescan and see what I have.
Does this sound right? Am I missing something or am I misinterpreting the data? Oh and yes I do see that I have a potential issue with the EGR downstream pressure reading. Hoses and tubes look good, I will go further with it after I get this misfire fixed or misfire troubleshooting leads me to the EGR.
Misfire Diagnosis Using Mode $06 (Advanced) - Taurus Car Club of America : Ford Taurus Forum
"TID $56 seems to always be potential misfire events."
Not that this is NOT V10 specific, but ... given the pointer to the OBD-II stuff in that post, and what I should have looked at first...
For a 2001, the OBD-II spec from Ford http://www.motorcraftservice.com/vdi...f/obdsm109.pdf says this:
$56 - "Cylinder events tested and number of events required for a 1000 rev test"
Top of page 11.
Find all years here:
Motorcraft Technical Resource
Sounds like normal running. Now that you don't have misfires on any one cylinder, sounds like you're good
Or not...
Not running okay this morning, misfire still there. I will scan again tonight.
How many miles do u have to log before it will generate mode06 data after a hard reset like this?
Seems it's one of those counters that needs to get to a certain point before the PCM starts to really take a good look at misfires.
"Look at the picture again and notice the value for TID $56 and the maximum threshold. I have obviously failed this test! These are potential misfire events. An event is any disruption in crankshaft acceleration, which can be caused by going over bumps in the road, the A/C compressor clutch engaging, or even just because of noise in the crankshaft signal. In order to count as a misfire, an event has to occur during a misfire check and have a certain acceleration profile, so the vast majority of events are not considered misfires (even if they are being caused by one). If more than a certain number of events (3000 in my case) are logged in a certain period of time (every key cycle) the PCM will do a 1000 rev misfire test to find out if the car is truly misfiring, and what cylinder/how often it is misfiring. This can only happen after the crankshaft profile correction portion of the misfire monitor has completed. Profile correction monitors crankshaft acceleration during a fuel-cutoff deceleration to "learn" the exact tooth profile on the crank position wheel. After a KAM reset or code clearing it requires you to coast (no brake) from 60-40mph 3 times to complete the monitor.
Now, is your '99 REALLY OBD-I? Does it actually say that on the underhood sticker?
You have an EGR, do you have an O2 sensor after the catalytic converter? (Just to make absolutely sure what's going on here).
TID$56 is supposed to increment, it's normal as noted in the OBDII manual. It's just a counter of "Cylinder events tested and number of events required for a 1000 rev test". I suspect your software's tagging of that entry as a "fail" is erroneous as is the TCCA poster's interpretation.
The "limit" of TID$56 will be 3000 if a V6, 4000 if a V8, and 5000 if a V10 as those are the number of "ignition events" required to represent 1000 revolutions of the engine. This is not a PASS/FAIL test although the software writer assumed it was.
"Typical EGR hose check malfunction thresholds:"
"DPFE sensor voltage: < 7 in H2O, > 7 in H2O"
You do not have a test results that indicates an EGR problem, you have a "false" red flag.
After clearing scans and computer and a day of driving I scanned again. Results showed 6 now had the misfire. Swapped in a good coil I had laying around. Rinsed and repeated and now 6 is clean. 10 now has a really low count like 65 so this could be a fluke or maybe just a really low level misfire. Either way it should be good for this trip this weekend.
I will scan again when I get back and go from there. On to the EGR next, I will likely go into a dealer first and pick their brain. Thanks for the help!
Like I said at the beginning I am trying to learn how to use this software. Sure I want to fix the truck but in the long run it will payoff if I learn how to use this new tool properly.
